vsharma81
12 months agoTuning in
Red light on Virgin Media 3 hub - can I get the box replaced?
Hi there, I've got a Virgin Hub 3. My internet access is fine but I have a solid red line on the front of my box which has been on there for months. I've done a reset of the box but the red light is still on there. Am I able to get the box replaced as it appears faulty.
When I spoke with a member of tech support, I'm not sure if they misunderstood me but they said I would need to upgrade to a Hub 5 or pay £40-£50 for a replacement Hub 3 box. If the box is faulty (as in the red light is being displayed when it shouldn't be and a reset hasn't worked), should the box not be replaced free of charge?
Would you be able to help?
