- Daniel_EtForum Team (Retired)
Hi Farrelly, thank you for your post.
In the first instance, please follow the below steps in the following order:
• Turn the power switch off on the back of the Hub
• Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
• Use the power switch to turn the unit back on
If after following the steps the router doesn't boot back up after a few minutes, or the red light returns when it does, it'll need replacing.
Regards,
Daniel- FarrellyTuning in
I've already rebooted twice, light is still red.
Please advise on next step
Hi Farrelly, thank you for your response.
In order to discuss this further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel
Related Content
- 2 years ago
- 1 year ago
- 3 years ago
- 5 years ago
- 7 months ago
