on 26-01-2024 15:46
My hub 3 is showing a red power light instead of the usual white power light. It is solid red and the top half is warm to the touch. I have seen that this means it needs replacing. Any advice?
Answered! Go to Answer
on 27-01-2024 15:04
Thanks for trying a factory reset, Lindawhite14 - I'm sorry things are still the same.
I'm going to send you a private message, to assist further with this, as we will need to book a Technician visit. Please look out for it in the top-right, white envelope or by tapping your profile picture, and selecting "Messages".
on 26-01-2024 16:20
Hi Lindawhite14,
Thanks for your post and welcome to the community.
Sincere apologies for the issues faced with your Hub, can we ask firstly have you performed a pin hole reset.
Also where is the box located?
Let us know,
on 26-01-2024 16:23
Thanks for coming back promptly. Yes we have done a pin hole reset twice. It is placed in an open position with plenty of air circulation.
on 26-01-2024 17:58
It's fried. Call it in as a fault on 0345 454 1111.
on 27-01-2024 15:04
