Red Light Hub 3 Overheating
gderwent
I have a solid red light on my virgin media Hub 3 for over 3 months. I’ve also been having issues with my WiFi dropping on a regular basis. I have called virgin media a few times and every time the advice is different by the technical people. I have done a reset of the wifi router recently and have taken out the wires and plugged them in again. Unfortunately the red light is still coming up.
3 REPLIES 3
gderwent
Hi, my VM Hub 3 has been on a solid red light for three months and VM are refusing to help or acknowledge there is a problem. Can anyone suggest a replacement router that can be used unitl I can change contract - or is this grounds for cancelling the contract without cost? Thanks
Matthew_ML
Hey gderwent, thank you for reaching out and I am sorry to hear this, also a warm welcome to the community.
Thank you trying these steps, I am going to send you a DM.
After the reset did you try this step;
Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight.
Matt - Forum Team
New around here?
I have sent you a DM, please reply when you can do.
Matt - Forum Team
New around here?
