quadX's avatar
quadX
Re: Hub 3 constant red light
Hello, I have the same issue (red light) and tried everything that is described above. I also did a full reset. Running tests confirms that the hub does not fully function (with Virgin link sent to us and login onto the hub via browser). I would appreciate a DM from a Virgin Media team member to arrange an engineer visit. Many thanks.
1 Reply
  • Alex_RM's avatar
    Alex_RM
    Hi quadX,
    Thanks for posting and welcome to our community 😊
    Sorry to hear you're having some issues with the hub. So I can get a few more details from you, I've popped you over a private message.
    Alex_Rm
