3 weeks ago
I am a new customer. I would like some technical advice so have tried calling your support number but the suggestion is to reset my hub.
I have also tried your chatbot but again get the same advice.
This is not my problem. Is it possible to actually speak to a human and discuss my problems?
DKenny
Answered! Go to Answer
3 weeks ago - last edited 3 weeks ago
What exactly are the issues you are having? This forum is a community help one - so there are quite a few "experts" on here who can offer advice and suggestions quickly.
A VM person will respond on here but it can take several days.
You could start by posting up the Hub data.....
Or if a wifi only issue - see below that
__________________
Post up your Hub/network connection details in the format below and someone will check to see if there is a problem there. In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
_________________________
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - if you are - it is clearly stated on the webpage.
You can also text VM on 0753 305 1809 include account name/number and what the issue is, there is also a “Chat” option on their website - but note that replies usually take longer. Or you can speak to the team on WhatsApp by logging into your online account via a mobile handset and there will be a link to speak to VM by Whats App (the number is 0780 3089 684 ) - you can use the same number for their other social media platforms too (TwitX/Fbook. etc) - so try them all
If not free to you… you will be charged £8/month for up to 3 pods. It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option. If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point(s), (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3). £40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
__________________
3 weeks ago
Hi, thanks for the info and advice.
At the moment I am simply trying to speak to speak to a human at VM. When I call their customer support line I seem to be stuck in an endless loop where the automated service just wants me to reset my hub.
I will try WhatsApp as you mention above.
Regards,
3 weeks ago
OK - but CS are generally not experts on technical or account issues - some people on here are and can direct you to the correct place to handle it
2 weeks ago
Hey dkenny, thank you for reaching out and a warm welcome to the community, I am so sorry to hear about your connection issues.
I have taken a look and I can see you've spoke to the team, did they manage to help at all?
Matt - Forum Team
New around here?
