Spoony36's avatar
Spoony36
Superfast
Poor Network and WIFI
I feel like i'm starting to get issues with my connection again and my WIFI seems a bit shabby lately.
I'm sure my power levels were fixed previously on multiple occasions and the last engineer said he had put something on my wire in the cabinet to advise other engineers not to move my wire or whatever it is in there.
but im not sure if someone has done something in the cabinet because my power levels seem to have rocketed from like 1 to over 7
3.0 Upstream channels
Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
0    49600000    38.8    5120    QAM 64    9
1    43100000    38.8    5120    QAM 64    10
2    36600000    38.3    5120    QAM 64    11
3    30100000    38.3    5120    QAM 64    12
4    23600000    37.8    5120    QAM 64    13
Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
0    ATDMA    0    0    0    0
1    ATDMA    0    0    0    0
2    ATDMA    0    0    0    0
3    ATDMA    0    0    0    0
4    ATDMA    0    0    0    0
3.1 Upstream channels
Channel    Channel Width (MHz)    Power (dBmV)    FFT Type    Modulation
14    10    33.5    2K    QAM 256
Channel    Channel Type    Number of Active Subcarriers    First Active Subcarrier (Hz)    T3 Timeouts    T4 Timeouts
14    OFDMA    200    74000000    0    0
    We avoid restarting the VM Hub, it is not a fix for external faults.
    The VM Hub has more plenty of signal from the street cabinet,
    distance is not the issue, line noise is behind the errors.
    Check all of your VM cables are secure at the wall and at the Hub or TV STBs.
    Check for a known service fault your street using both of :
    Call the local fault line: 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
  • 3.0 Downstream channels
    Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
    1    331000000    7.4    41    QAM 256    25
    2    139000000    7.4    39    QAM 256    1
    3    147000000    7.3    39    QAM 256    2
    4    155000000    7.3    39    QAM 256    3
    5    163000000    7.2    40    QAM 256    4
    6    171000000    6.9    39    QAM 256    5
    7    179000000    6.9    39    QAM 256    6
    8    187000000    6.9    39    QAM 256    7
    9    195000000    7.1    39    QAM 256    8
    10    203000000    6.7    39    QAM 256    9
    11    211000000    6.9    39    QAM 256    10
    12    219000000    6.6    40    QAM 256    11
    13    227000000    6.6    40    QAM 256    12
    14    235000000    6.5    39    QAM 256    13
    15    243000000    6.3    39    QAM 256    14
    16    251000000    6.5    40    QAM 256    15
    17    259000000    6.3    40    QAM 256    16
    18    267000000    6.7    40    QAM 256    17
    19    275000000    6.7    40    QAM 256    18
    20    283000000    7    40    QAM 256    19
    21    291000000    7.2    40    QAM 256    20
    22    299000000    7.2    40    QAM 256    21
    23    307000000    7.4    41    QAM 256    22
    24    315000000    7.3    41    QAM 256    23
    25    323000000    7.4    41    QAM 256    24
    26    339000000    7.6    40    QAM 256    26
    27    347000000    7.7    41    QAM 256    27
    28    355000000    7.7    41    QAM 256    28
    29    363000000    8.1    41    QAM 256    29
    30    371000000    7.9    41    QAM 256    30
    31    379000000    8.2    41    QAM 256    31
    32    387000000    8    41    QAM 256    32
    Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
    1    Locked    41    228420    17893
    2    Locked    39    262412    52398
    3    Locked    39    243316    46446
    4    Locked    39    472720    121405
    5    Locked    40    211760    47339
    6    Locked    39    463326    101993
    7    Locked    39    381861    78340
    8    Locked    39    415335    83841
    9    Locked    39    376335    76738
    10    Locked    39    363179    70602
    11    Locked    39    350613    64132
    12    Locked    40    340167    58953
    13    Locked    40    327898    53428
    14    Locked    39    320144    49640
    15    Locked    39    312422    46115
    16    Locked    40    305832    43314
    17    Locked    40    296611    39581
    18    Locked    40    288385    36324
    19    Locked    40    279854    32912
    20    Locked    40    269432    29559
    21    Locked    40    260384    26505
    22    Locked    40    251254    23462
    23    Locked    41    243149    21185
    24    Locked    41    236979    19500
    25    Locked    41    233686    18660
    26    Locked    40    224790    16630
    27    Locked    41    220372    15829
    28    Locked    41    215805    15044
    29    Locked    41    209078    13686
    30    Locked    41    201645    12310
    31    Locked    41    193335    11047
    32    Locked    41    186132    9895
    3.1 Downstream channels
    Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
    159    94    4K    1840    QAM 4096    1108
    Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
    159    Locked    42    6.0    2672293037    33608
    My concern would be the high numbers of Pre RS Errors & Post RS Errors affecting all channels.
    • Spoony36's avatar
      Spoony36
      Superfast
      I do restart my hub quite regularly because of those
      System up time    :    8day(s)22h:15m:22s
      I am quite a way from the cabinet and had a repull with RG11 cable being used
