caesarrye's avatar
caesarrye
Separate wifi network for electric heaters
I've unintentionally merged my two wifi networks and now I can only control my heaters manually.
The CONNECT app asked me to merge the networks because there was some negative impact on performance but I really need the two because the heaters will only connect to the slower Hz network.
I have no recollection of how I did this originally and can't find a guide in Virgin Media. Anyone able to point me in the right direct?
Thanks in advance
  • 1) Critical !!! Uninstall the VM Connect app from all devices in the house.
    2) Login to the VM Hub at http://192.168.0.1/   using the Hub password ( not the Wi-Fi password )
    3) In the Wireless settings of the VM Hub, DISABLE Smart Wi-Fi aka Wireless Channel Optimization.
    4) Now the VM Hub will allow you to split the SSIDs,   Change the SSID of the 5GHz band as needed.
    5) Do not re-install the Connect app or in no time it will re-merge the SSIDs.
    6) Note VM Pods do not support split SSIDs.
    • caesarrye's avatar
      caesarrye
      Worked perfectly, Alessandro. And VMC deleted. What a waste of time it was.
      Thanks for your help
        No one really needs the Connect app. You can manage everything via the Hubs admin console.  I suspect the app is necessary for those who can’t be without an app?
  • I set up my new HUB 3 to use the same SSIDs as my old router but due to VM's password policy had to change those, so it was bit of a pain reconnecting devices.
    Tried the Connect app for a few minutes, then found it had turned optimisation back on, activated the guest network and was requesting to merge SSIDs.
    Needless to say it was uninstalled straight away.
