LR1982's avatar
LR1982
WiFi on a separate electricity circuit?
Looking for help please on the best way to get wifi in our garden building which is on a separate electricity circuit. We moved house about a year ago and moved BT with us but the speeds just aren’t good enough for our busy house. We switched to virgin recently but with BT the wifi hub worked in the garden building (Ethernet cable installed), I can’t seem to get the virgin equivalent to do the same. Is it user error or do I need something else?
Thanks for any advice 😀
  • Remove the VM Pod from the end of the cable at the shed and attach your laptop to confirm the cable is working.
    I have recently read a post on forum saying the Black VM pods can work over a network cable as a back haul,
    but I have not seen the same for the White Pods & they have been around for much longer.
    I'd replace the VM Pod in the shed with a retail Wi-Fi Access Point or better a retail Wi-Fi Router configured in Access Point mode so as to have Wi-Fi & network sockets. Having you own Wi-Fi kit is so much more flexible because you can configure it as needed.
