1214sam's avatar
1214sam
New to virgin red light on hub
New to virgin Broadband hub 3, light is red only had for a week. It was when it was installed. when went amber for a day now red again. Should I be concerned? Should I phone them ?
Wifi has been working ok I think. When I check status a couple of times been stating I have a problem, but not really noticed.
Already annoyed,  anyway as after a few days of contract they sent a message of increased my price.
Thank you in advance
  • Login in to the Hub 3 menu at http://192.168.0.1/
    use the numeric HUB PASSWORD from the bottom side label. ( this is not the Wi-Fi password )
    Run the Network diagnostic tool
    Scroll down through the results and find the Temperature entry. Is it Normal ?
  • Paul_DN's avatar
    Paul_DN
    Hi 1214sam,
    Thank you for reaching out to us in our community and welcome both here and to Virgin Media, we are sorry for any concerns caused by the red light showing on your Router which you have on on pretty much from the beginning.
    I was able to locate you on our system with the details we have for you and it does look like there is a potential issue, it is advised that you first try a pin reset on the Router, this will rule out any software issues, pleas push a pin/ paper clip in the reset hole, keep it pressed in for a full timed 1 minute, once done allow 15 minutes to settle.
    Paul.
    • 1214sam's avatar
      1214sam
      Thank you for getting back. I have done the pin reset today. The hub is still red. Any help or should I call virgin?
      Thank you
    • 1214sam's avatar
      1214sam
      Thank you, I have done the above. It states temperature is normal. So am I assuming the hub is fine. Although I still have this red light that goes amber once in a while, which is very annoying. As a new customer one would assume I would get a new working hub with a white light.
      Thank you at least im a little relieved that its not over heating.
      • Martin_N's avatar
        Martin_N
        Hi 1214sam,
        Thank you for your post. I'm very sorry to hear about the light going to red on the hub.
        We will need to arrange to have this replaced. I will private message you now to confirm your details.
        ^Martin
