wakeuph8's avatar
wakeuph8
Network Routing problem
Hi there,
I'm currently having a bit of an issue with any device in my house connecting through the VM router that I have. I've tried resetting it entirely and leaving it as default and i've tried changing my dns to avoid VM's DNS to 1.1.1.1 / 1.0.0.1 amongst others.
However the issue i'm facing seems to be a routing problem, websites and IP addresses at random that I've confirmed others can connect to seem to be impossible for me to reach as of ~9am thismorning.
āžœ traceroute forums.zwift.com
traceroute to gozwift.hosted-by-discourse.com (184.105.99.75), 64 hops max, 40 byte packets
 1  192.168.0.1 (192.168.0.1)  8.065 ms  7.443 ms  8.332 ms
 2  * * *
 3  belf-core-2a-ae20-650.network.virginmedia.net (62.254.33.53)  21.755 ms  20.277 ms  18.167 ms
 4  * * *
 5  * * *
 6  * * *
 7  * * *
 8  * * *
 9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
... Repeat forever
And another:
traceroute: Warning: app.netdata.cloud has multiple addresses; using 44.207.131.212
traceroute to main-ingress-545609a41fcaf5d6.elb.us-east-1.amazonaws.com (44.207.131.212), 64 hops max, 40 byte packets
 1  192.168.0.1 (192.168.0.1)  8.204 ms  6.379 ms  7.615 ms
 2  * * *
 3  belf-core-2a-ae20-650.network.virginmedia.net (62.254.33.53)  16.438 ms  18.409 ms  16.762 ms
 4  * * *
 5  * * *
 6  * * *
 7  * * *
... repeat forever
I spent quite a while debugging my internal network but I dont see an issue there. The fact that it's getting out to VM and then failing makes me think it's not an issue on my side. I've also made no changes to my internal network in weeks aside from resetting the router to defaults thismorning in the hopes that it'd fix the issue.
Is there anything that can be done?
  • Hi All,
    We're sorry to hear that you've been having some problems accessing certain website. We've raised this with our network team and they have raised this issue under the ticket number F011338432.
    We're glad to hear that this issue is resolved for some of you, and our team are continuing to investigate to ensure this is fixed as quickly as possible.
    ModTeam
  • linwelin's avatar
    linwelin
    I am using a wired connection but i cant seem to connect to some websites, for instance www.x.com done a ping and tracert:
    C:\Users\yonat>ping www.x.com
    Pinging x.com [104.244.42.193] with 32 bytes of data:
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Ping statistics for 104.244.42.193:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
    C:\Users\yonat>tracert www.x.com
    Tracing route to x.com [104.244.42.193]
    over a maximum of 30 hops:
    1 1 ms 1 ms 1 ms 192.168.0.1
    2 * * * Request timed out.
    3 11 ms 9 ms 11 ms belf-core-2a-ae20-650.network.virginmedia.net [62.254.33.53]
    4 * * * Request timed out.
    5 * * * Request timed out.
    6 * * * Request timed out.
    Does anything look wrong with this?
    Router status
    3.0 Downstream channels
    13310000006.443QAM 25625
    21390000001.841QAM 2561
    31470000002.442QAM 2562
    41550000002.939QAM 2563
    51630000003.242QAM 2564
    61710000003.342QAM 2565
    71790000003.542QAM 2566
    81870000003.841QAM 2567
    91950000004.342QAM 2568
    102030000004.642QAM 2569
    112110000004.943QAM 25610
    122190000004.943QAM 25611
    132270000004.742QAM 25612
    142350000004.742QAM 25613
    152430000004.942QAM 25614
    16251000000543QAM 25615
    172590000005.143QAM 25616
    18267000000543QAM 25617
    192750000004.843QAM 25618
    20283000000543QAM 25619
    212910000005.543QAM 25620
    222990000005.843QAM 25621
    233070000006.143QAM 25622
    243150000006.343QAM 25623
    253230000006.443QAM 25624
    263390000006.842QAM 25626
    27347000000742QAM 25627
    28355000000743QAM 25628
    293630000006.943QAM 25629
    303710000007.143QAM 25630
    313790000007.343QAM 25631
    1Locked4330897005
    2Locked41846115427
    3Locked422194507657
    4Locked39415836894
    5Locked423571610583
    6Locked428691128493
    7Locked4256673632
    8Locked411705524714
    9Locked4254357375
    10Locked42624313713
    11Locked43745423247
    12Locked43693219866
    13Locked42311408
    14Locked4224834589
    15Locked4246188654
    16Locked43234405
    17Locked43220286
    18Locked43207313
    19Locked4339508206
    20Locked438011218
    21Locked43521763
    22Locked43117132
    23Locked43151207
    24Locked437291166
    25Locked43490761
    26Locked4221085095
    27Locked4220174792
    28Locked43247458
    29Locked43310525
    30Locked4320864815
    31Locked4332068282
    3.1 Downstream channels
    33944K1840QAM 40961108
    33Locked446.554428562727
    Router status
    Refresh data
    3.0 Upstream channels
    04960000048.55120QAM 641
    14310000049.55120QAM 642
    23660000050.55120QAM 643
    33010000051.85120QAM 644
    423600000535120QAM 645
    0ATDMA0000
    2ATDMA0010
    3ATDMA0010
    4ATDMA0020
    3.1 Upstream channels
    610.441.22KQAM 256
    6OFDMA2087400000000
      I'd be concerned about the Post RS Errors aka uncorrected errors affecting all 3.0 Downstream channels,
      if these numbers are still increasing the problem persists.
      1Locked4330897005
      2Locked41846115427
      3Locked422194507657
      4Locked39415836894
      5Locked423571610583
      6Locked428691128493
      7Locked4256673632
      8Locked411705524714
      9Locked4254357375
      10Locked42624313713
      11Locked43745423247
      12Locked43693219866
      The 3.0 Upstream power levels are testing the upper limits, this matters because it is the measure of how high the VM Hub has to transmit in order to be received at the street cabinet.
      I can ping www.x.com at all 4 IPs listed in the DNS lookup without issue.  ( from Colchester, Essex )
  • I have the same problem I can't get teamviewer to work because I can't route to
      gb-man-anx-r002.router.teamviewer.com
    My traceroute is similar to yours i.e.
    traceroute gb-man-anx-r002.router.teamviewer.com
    traceroute to gb-man-anx-r002.router.teamviewer.com (37.252.232.101), 30 hops max, 60 byte packets
    1 _gateway (192.168.0.1) 3.254 ms 4.888 ms 4.881 ms
    2 * * *
    3 belf-core-2a-ae20-650.network.virginmedia.net (62.254.33.53) 26.997 ms 28.985 ms 28.978 ms
    4 * * *
    5 * * *
    Both forums.zwift.com and app.netdata.cloud also fail but most hosts ping without a problem.
    Problem has been going on all day.
    Given that we are both routing through belf-core-2a-ae20-650.network.virginmedia.net I suspect that is where the routing issue is.
    • wakeuph8's avatar
      wakeuph8
      Thanks for that, i'm glad it's not an issue for just me! I get the same issue with your teamviewer URL. I contacted VM support via WhatsApp and they say they've also passed it along to the backend team and essentially to wait for 48 hours while they get a look.
      I'm assuming it's a common route that's broken somewhere as i've found a few others now where the same issue happens, I cant even do a "whois" on a domain or IP address without it failing because it has to contact a server it no longer can:
      āžœ whois virginmedia.com
      whois: connect(): Operation timed out
    • wakeuph8's avatar
      wakeuph8
      Great find, thanks! All signs do seem to point to a similar issue to that Warrington thread, it was actually the reason I'd posted in the first place, hopefully it's sorted quickly
      • nymins's avatar
        nymins
        Yep, been experiencing these issues all day too. Some random websites just not working, twitter.com, battle.net to name a few. Based in Belfast.
  • Hey,
    Having the same issues with belf-core-2a-ae20-650.network.virginmedia.net which have just started in the last 24-48 hours. Cannot access a significant portion of the internet including my work vpn endpoints, arturia.com, twitter.com and vps.ovh.net. Had a day's downtime last week for "maintenance".
  • I'm in Belfast too. Have had problems all day on different sites. Dh upset as he can't get on to a few gaming sites that he always uses. Phoned Virgin and they said they would pass the information to an engineer.
  • I've been having the same issues all day. Can't connect to work VPN and many websites. Eventually tracked them down to routes disappearing after hitting
    Hopefully they fix this soon
  • Just a few minutes ago my issues disappeared, hopefully everyone else has the same experience soon.
    • ModTeam's avatar
      ModTeam
      Moderator
      Hi All,
      ModTeam
      • nymins's avatar
        nymins
        Issue seems to be gone for me too. Thanks for sorting!
