linwelin's avatar
linwelin
Re: Network Routing problem
I am using a wired connection but i cant seem to connect to some websites, for instance www.x.com done a ping and tracert:
C:\Users\yonat>ping www.x.com
Pinging x.com [104.244.42.193] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 104.244.42.193:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\yonat>tracert www.x.com
Tracing route to x.com [104.244.42.193]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.0.1
2 * * * Request timed out.
3 11 ms 9 ms 11 ms belf-core-2a-ae20-650.network.virginmedia.net [62.254.33.53]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
Does anything look wrong with this?
Router status
3.0 Downstream channels
13310000006.443QAM 25625
21390000001.841QAM 2561
31470000002.442QAM 2562
41550000002.939QAM 2563
51630000003.242QAM 2564
61710000003.342QAM 2565
71790000003.542QAM 2566
81870000003.841QAM 2567
91950000004.342QAM 2568
102030000004.642QAM 2569
112110000004.943QAM 25610
122190000004.943QAM 25611
132270000004.742QAM 25612
142350000004.742QAM 25613
152430000004.942QAM 25614
16251000000543QAM 25615
172590000005.143QAM 25616
18267000000543QAM 25617
192750000004.843QAM 25618
20283000000543QAM 25619
212910000005.543QAM 25620
222990000005.843QAM 25621
233070000006.143QAM 25622
243150000006.343QAM 25623
253230000006.443QAM 25624
263390000006.842QAM 25626
27347000000742QAM 25627
28355000000743QAM 25628
293630000006.943QAM 25629
303710000007.143QAM 25630
313790000007.343QAM 25631
1Locked4330897005
2Locked41846115427
3Locked422194507657
4Locked39415836894
5Locked423571610583
6Locked428691128493
7Locked4256673632
8Locked411705524714
9Locked4254357375
10Locked42624313713
11Locked43745423247
12Locked43693219866
13Locked42311408
14Locked4224834589
15Locked4246188654
16Locked43234405
17Locked43220286
18Locked43207313
19Locked4339508206
20Locked438011218
21Locked43521763
22Locked43117132
23Locked43151207
24Locked437291166
25Locked43490761
26Locked4221085095
27Locked4220174792
28Locked43247458
29Locked43310525
30Locked4320864815
31Locked4332068282
3.1 Downstream channels
33944K1840QAM 40961108
33Locked446.554428562727
Router status
Refresh data
3.0 Upstream channels
04960000048.55120QAM 641
14310000049.55120QAM 642
23660000050.55120QAM 643
33010000051.85120QAM 644
423600000535120QAM 645
0ATDMA0000
2ATDMA0010
3ATDMA0010
4ATDMA0020
3.1 Upstream channels
610.441.22KQAM 256
6OFDMA2087400000000
1 Reply
    I'd be concerned about the Post RS Errors aka uncorrected errors affecting all 3.0 Downstream channels,
    if these numbers are still increasing the problem persists.
    1Locked4330897005
    2Locked41846115427
    3Locked422194507657
    4Locked39415836894
    5Locked423571610583
    6Locked428691128493
    7Locked4256673632
    8Locked411705524714
    9Locked4254357375
    10Locked42624313713
    11Locked43745423247
    12Locked43693219866
    The 3.0 Upstream power levels are testing the upper limits, this matters because it is the measure of how high the VM Hub has to transmit in order to be received at the street cabinet.
    I can ping www.x.com at all 4 IPs listed in the DNS lookup without issue.  ( from Colchester, Essex )
