spoulson's avatar
spoulson
Routing problems
You have a problem with routing - zayo.com is not forwarding your packets for certain IPs. This is causing me much pain and I am considering cancelling my contract
Compare the following traceroutes:
Virgin:
```traceroute -I amsvpn.vrt.sourcefire.com
traceroute to amsvpn.vrt.sourcefire.com (172.110.205.185), 64 hops max, 48 byte packets
1  192.168.0.1 (192.168.0.1)  8.055 ms  71.147 ms  139.188 ms
2  * * *
3  80.255.200.164 (80.255.200.164)  10.555 ms  14.502 ms  9.166 ms
4  * * *
5  aor.uk-lon03a-ri1.network.virginmedia.net (62.254.42.174)  21.328 ms  11.761 ms  29.426 ms
6  * * *
7  uk-lon01b-ri1-ae-25-0.aorta.net (84.116.136.102)  70.679 ms  156.305 ms  15.548 ms
8  * * *
9  ae3.cr1.lhr15.uk.eth.zayo.com (64.125.28.150)  76.189 ms  20.585 ms  18.454 ms
10  * * *
11  * * *
packets get lost here
Compare with another ISP
1  192.168.113.114 (192.168.113.114)  140.808 ms  34.309 ms  3.259 ms
2  255.0.0.0 (255.0.0.0)  76.861 ms  44.147 ms  55.541 ms
3  * * *
4  109.249.132.9 (109.249.132.9)  43.484 ms  53.890 ms  47.197 ms
5  * * *
6  * 109.249.132.123 (109.249.132.123)  59.909 ms *
7  core6-hu0-7-0-15.faraday.ukcore.bt.net (195.99.127.50)  62.828 ms * *
8  * 166-49-209-194.gia.bt.net (166.49.209.194)  39.966 ms  51.990 ms
9  ae15.mpr1.lhr15.uk.above.net (195.66.224.76)  48.269 ms  49.551 ms  52.558 ms
10  ae3.cr1.lhr15.uk.eth.zayo.com (64.125.28.150)  49.399 ms  46.367 ms  54.104 ms
11  213.161.83.239 (213.161.83.239)  50.270 ms  59.591 ms  92.833 ms
12  vl2803.amscore2.vrt.sourcefire.com (172.110.205.57)  49.739 ms  57.692 ms  43.337 ms
13  amsvpn.vrt.sourcefire.com (172.110.205.185)  49.761 ms  41.806 ms  56.170 ms
  • It turns out this isn't a routing problem. I think the zayo.com switch has been configured to drop packets sourced from 86.14.162.0/24 or more specific. I switched to modem mode which reallocated my IP out of this range and I can get to sourcefire.com now.  Thanks to the community for support. However, during this process I must say I found Virgin Media's support poor and I will consider this when the contract runs out.
  • Carley_S's avatar
    Carley_S
    Hi spoulson
    Sorry to hear that you've not been able to access zayo.com.
    Are you able to access this through a Virgin Media service without the VPN enabled?
    • spoulson's avatar
      spoulson
      Everything works otherwise except can't connect to amsvpn.vrt.sourcefire.com. I've also seen the same problem at another location that uses Virgin but works fine with other ISPs. The packet is meant to route to amsvpn.vrt.sourcefire.com (172.110.205.185)  but doesn't go beyond ae3.cr1.lhr15.uk.eth.zayo.com (64.125.28.150) either this server is dead or is rejecting packets from VM, another route is needed. See traceroute. This looks like something that should be raised with your network team like I've seen in other discussions here.
    On our VM connection we can reach : amsvpn.vrt.sourcefire.com
    > ping  amsvpn.vrt.sourcefire.com
    Pinging amsvpn.vrt.sourcefire.com [172.110.205.185] with 32 bytes of data:
    Reply from 172.110.205.185: bytes=32 time=25ms TTL=240
    Reply from 172.110.205.185: bytes=32 time=22ms TTL=240
    Reply from 172.110.205.185: bytes=32 time=23ms TTL=240
    Ping statistics for 172.110.205.185:
        Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
        Minimum = 22ms, Maximum = 25ms, Average = 23ms
    • cje85's avatar
      cje85
      Wise owl
      It's working for me too:
      tracert amsvpn.vrt.sourcefire.com
      Tracing route to amsvpn.vrt.sourcefire.com [172.110.205.185]
      over a maximum of 30 hops:
        1     1 ms     1 ms     1 ms  RT-AX86U-9080 [192.168.1.1]
        2    17 ms    13 ms    14 ms  10.53.39.9
        3    15 ms    35 ms    12 ms  80.255.195.242
        4     *        *        *     Request timed out.
        5    34 ms    30 ms    30 ms  86.85-254-62.static.virginmediabusiness.co.uk [62.254.85.86]
        6     *        *        *     Request timed out.
        7    23 ms    31 ms    41 ms  uk-lon01b-ri1-ae-23-0.aorta.net [84.116.135.30]
        8     *        *        *     Request timed out.
        9    25 ms    26 ms    24 ms  ae3.cr1.lhr15.uk.eth.zayo.com [64.125.28.150]
       10    26 ms    25 ms    26 ms  213.161.83.239
       11    27 ms    24 ms    23 ms  vl2803.amscore2.vrt.sourcefire.com [172.110.205.57]
       12    27 ms    26 ms    25 ms  amsvpn.vrt.sourcefire.com [172.110.205.185]
      • spoulson's avatar
        spoulson
        You have a different route:
        Yours: uk-lon01b-ri1-ae-23-0.aorta.net [84.116.135.30] -> 64.125.28.150
        Mine: uk-lon01b-ri1-ae-25-0.aorta.net (84.116.136.102) -> 64.125.28.150
        64.125.28.150 has an ACL entry to drop packets from 84.116.136.102  ¯\_(ツ)_/¯
    • spoulson's avatar
      spoulson
      @Client62 can you do the traceroute for that. My hypothesis is the 84.116.135.30- > 64.125.28.150 hop is the problem.
        First I would like to see your result of a ping test.
        Unless you are also near Colchester, Essex my routing would differ from yours.
  • spoulson's avatar
    spoulson
    @ Carley_S  see https://community.virginmedia.com/discussions/Wireless/routing-problems-to-google-dns/5531299
      Routing to dns.google works perfectly :-
      > nslookup hp.com 8.8.8.8
      Server:  dns.google
      Address:  8.8.8.8
      Non-authoritative answer:
      Addresses:  15.72.80.135
                15.73.145.56
  • Roger_Gooner's avatar
    Roger_Gooner
    It works for me.
    C:\>tracert amsvpn.vrt.sourcefire.com
      1     2 ms     1 ms     1 ms  192.168.0.1
      2     *        *        *     Request timed out.
      3     8 ms    11 ms     8 ms  80.255.195.134
      4     8 ms     8 ms     7 ms  haye-core-2a-ae1-0.network.virginmedia.net [80.3.176.177]
      5     *        *        *     Request timed out.
      6    44 ms    11 ms    16 ms  aor.uk-lon03a-ri1.network.virginmedia.net [62.254.42.174]
      7     *        *        *     Request timed out.
      8    12 ms    20 ms    11 ms  uk-lon01b-ri1-ae-25-0.aorta.net [84.116.136.102]
      9     *        *        *     Request timed out.
     10     *        *        *     Request timed out.
     11    16 ms    15 ms    14 ms  213.161.83.239
     12    14 ms    14 ms    14 ms  vl2803.amscore2.vrt.sourcefire.com [172.110.205.57]
     13    15 ms    17 ms    17 ms  amsvpn.vrt.sourcefire.com [172.110.205.185]
    Trace complete.
    C:\>
    • spoulson's avatar
      spoulson
      Thanks! Your route avoids the  84.116.135.30- > 64.125.28.150 hop which I think is the problem.
      • cje85's avatar
        cje85
        Wise owl
        Your traceroute goes through the same hop as Roger's:
        Yours:
        Roger:
        My traceroute (posted earlier) goes through the one you mentioned but works fine:
        Can you confirm exactly which server you think has a problem? Is it 84.116.135.30 which works for me or 84.116.136.102 which works for Roger?
  • spoulson's avatar
    spoulson
    This is my traceroute
    2  * * *
    4  * * *
    6  * * *
    8  * * *
    (stops here)
  • legacy1's avatar
    C:\Windows\System32>tracert amsvpn.vrt.sourcefire.com
      1     6 ms     6 ms     6 ms  10.112.32.133
      2    10 ms    13 ms     9 ms  80.255.196.176
      3     *        *        *     Request timed out.
      4    14 ms     9 ms     9 ms  aor.uk-lon03a-ri1.network.virginmedia.net [62.254.42.174]
      6    13 ms    10 ms    10 ms  uk-lon01b-ri1-ae-25-0.aorta.net [84.116.136.102]
      8    19 ms    18 ms    16 ms  ae3.cr1.lhr15.uk.eth.zayo.com [64.125.28.150]
      9    27 ms    18 ms    19 ms  213.161.83.239
     10    18 ms    15 ms    15 ms  vl2803.amscore2.vrt.sourcefire.com [172.110.205.57]
     11    15 ms    16 ms    13 ms  amsvpn.vrt.sourcefire.com [172.110.205.185]
    Trace complete.
    fine here
    Still no ping test from the OP.  A pity ... I guess that means it works.
      1     2 ms     2 ms     2 ms  192.168.0.1
      3    13 ms    14 ms    12 ms  80.255.193.200
      6    19 ms    20 ms    19 ms  aor.uk-lon03a-ri1.network.virginmedia.net [62.254.42.174]
      8    21 ms    20 ms    22 ms  uk-lon01b-ri1-ae-23-0.aorta.net [84.116.135.30]
     10    25 ms    26 ms    25 ms  ae3.cr1.lhr15.uk.eth.zayo.com [64.125.28.150]
     11    23 ms    23 ms    24 ms  213.161.83.239
     12    27 ms    26 ms    24 ms  vl2803.amscore2.vrt.sourcefire.com [172.110.205.57]
     13    25 ms    33 ms    24 ms  amsvpn.vrt.sourcefire.com [172.110.205.185]
    Trace complete.
    • spoulson's avatar
      spoulson
      Suffice to say ping doesn't work because the 84.116.135.30- > 64.125.28.150 hop fails
      PING amsvpn.vrt.sourcefire.com (172.110.205.185): 56 data bytes
      Request timeout for icmp_seq 0
      Request timeout for icmp_seq 1
      Request timeout for icmp_seq 2
      Request timeout for icmp_seq 3
      Request timeout for icmp_seq 4
      Request timeout for icmp_seq 5
      Successful routes I see make an alternative 84.116.135.30- > 213.161.83.239 hop
      • cje85's avatar
        cje85
        Wise owl
        At the start of the thread your problem was with 84.116.136.102, now it seems to have changed to  84.116.135.30, is that correct?
        Either way there's no problem with 84.116.135.30 for me:
          1     1 ms    <1 ms    <1 ms  RT-AX86U-9080 [192.168.1.1]
          2    12 ms    10 ms    10 ms  10.53.39.9
          3    18 ms    11 ms    10 ms  80.255.195.242
          5    31 ms    21 ms    26 ms  86.85-254-62.static.virginmediabusiness.co.uk [62.254.85.86]
          7    22 ms    27 ms    19 ms  uk-lon01b-ri1-ae-23-0.aorta.net [84.116.135.30]
          9    28 ms    25 ms    25 ms  ae3.cr1.lhr15.uk.eth.zayo.com [64.125.28.150]
         10  25 ms    27 ms    45 ms  213.161.83.239
         11    26 ms    26 ms    23 ms  vl2803.amscore2.vrt.sourcefire.com [172.110.205.57]
         12    43 ms    25 ms    23 ms  amsvpn.vrt.sourcefire.com [172.110.205.185]
  • spoulson's avatar
    spoulson
