StillHoping's avatar
StillHoping
3 years ago
Latency and Packet Loss Spikes for Months, Are These Power Levels Normal?
Hey everyone, for the last few months we have been having very high packet loss and latency spikes (ranging from only a few seconds to a few hours at a time). For a quick example here is the connection today to OpenDNS. With average latency of around 900ms during the window (the graph is for 3 hours).
Before and after will be okay with latency of between 10 and 21ms. Local traffic is completely fine. The box is a SuperHub 3 and has been running in Modem Mode for years.
I have been trying everything and speaking to Virgin Media but as the issue is intermittent they are not interested in investigating. One final thought I have is that it might be related to power levels. I don't really know anything but I feel the T3 timeouts look a bit high. What do people think? This was also during a period of the connection working, will try and capture it during a spike next time. Also, thank you so much for any time you spent on this. It has been driving me insane.
13310000005.438256 qam25
23390000005.538256 qam26
33470000005.538256 qam27
4355000000538256 qam28
53630000005.138256 qam29
6371000000538256 qam30
73790000005.538256 qam31
83870000005.538256 qam32
93950000005.438256 qam33
104030000005.638256 qam34
114110000005.538256 qam36
124190000005.138256 qam37
134270000005.138256 qam38
144350000004.338256 qam39
154430000004.137256 qam35
164510000004.138256 qam40
174590000003.937256 qam41
184670000003.737256 qam42
194750000003.437256 qam43
204830000002.737256 qam44
214910000002.737256 qam45
224990000002.537256 qam46
235070000002.237256 qam47
245150000002.538256 qam48
1Locked38.9124
2Locked38.6183
3Locked38.6100
4Locked38.600
5Locked38.6150
6Locked38.9150
7Locked38.6100
8Locked38.670
9Locked38.660
10Locked38.950
11Locked38.650
12Locked38.600
13Locked38.650
14Locked38.610
15Locked37.350
16Locked38.660
17Locked37.680
18Locked37.680
19Locked37.650
20Locked37.650
21Locked37.640
22Locked37.6230
23Locked37.620
24Locked38.670
14960000049512064 qam1
23660000048.8512064 qam3
32360006848512016 qam5
43010000048.3512032 qam4
54310000048.8512064 qam2
1ATDMA0040
2ATDMA0020
3ATDMA00100
4ATDMA0030
5ATDMA0040
  • Hi StillHoping
    Thanks for your post, welcome to the Community Forums! Sorry to hear you're having trouble with your broadband service.
    We've struggled to locate the backend of your services from here to be able to look into this more closely, however I've dropped you a message so I can take your account details and look on our side. We can run further diagnostic checks from there.
  • Hi StillHoping
    Thanks for providing your account details via PM.
    I've had a look and your signal levels all look fine from here, however we haven't been able to run further diagnostic checks as it looks like you're in modem mode.
    If possible, can you please hop out of modem mode and into router mode so we can run further tests for you?
    Thanks😊
  • legacy1's avatar
    I been very disappointed if you don't find anything wrong in router mode😞
  • Hi @Beth_G, thank you for having a look. We will look at switching over to the router mode of the super hub 3 so you can run more complete tests after the Christmas period is over.
    However I have had the opportunity to set up a more complete testing suite on our side and after analysing some local traffic I can replicate the latency spike. Here is an example of a persistent latency issue that we saw above.
    And here is a triggered latency issue for a few minutes:
    The latter of which occurred while continuously uploading to the internet (I have tested this locally and there is no latency impact when copying to/from a local server at 350Mbps).
    After which I can across this buffer bloat test showing just how extreme the increase in latency is while uploading:
    https://www.waveform.com/tools/bufferbloat?test-id=52c72849-475c-406f-bca6-35f4b779493c
    We are on the M500 package (so in theory 52Mbps upload) but something we see only on occasion.
    In theory SQM (which we have and is "automagically" enabled) should help but with such varying bandwidth it seems pretty difficult to solve. Maybe something like `autorate-ingress` in openwrt would help but this is definitely a plaster to cover a bigger upstream problem.
    • Martin_N's avatar
      Martin_N
      Thank you for that information. If you can please let us know when you have been able to take the hub out of modem mode.
      ^Martin
      • StillHoping's avatar
        StillHoping
        Thank you @Martin. I will change it on Tuesday (working hours) for you to have a look at (unless Saturday/Sunday/Monday works in which case let me know).
        Just coming back to share some additional latency graphs from today which has had two particular bad periods (during which time there was limited local traffic on the network). The below graphs are for Facebook but true for any outbound traffic.
        Also would encourage anyone who is facing similar issues to use SmokePing for long term monitoring (with a very low polling time, we are using 3 pings every minute).
  • Testing over the weekend and it does look like there is something happening on the hub occasionally which causes periods of slow packet processing and/or packets drops.
    It looks similar to this issue where a hub replacement solved the issue: https://community.virginmedia.com/t5/Networking-and-WiFi/Hub3-in-modem-mode-ping-spikes-and-packet-loss/td-p/5384022/page/2
    However the good news it that whenever latency to the modem increases, it can just be restarted and it will be okay until the process on the SuperHub 3 starts again (and then it is just a reboot away from being okay). This is frustrating but at least there is a workable solution in the meantime.
    • Steven_L's avatar
      Steven_L
      Thanks for coming back to us StillHoping, I can see that there is an SNR fault logged in your area at the moment. This has been open since the 4th January and has a current estimated fix time of 12.30 on Thursday 11th January.
      Kind Regards,
      Steven_L
      • jpeg1's avatar
        jpeg1
        The data you gave in your first post showed QAM level errors on the upstream, and many T3 errors. I'm slightly surprised that these weren't commented on.
        It would be helpful if you posted the Hub data again when the reported fault has been cleared.
