PonniM's avatar
PonniM
Intermittent frequent ping spikes, rare packet loss and high Post-RS errors
Hi all, hoping to resolve the connection issues that I have experienced since around May/June last year. I've already had 3 technicians come out on 2 separate occasions to investigate and they recommended that I come here. They suspect I need a network engineer to investigate but told me they were unable to arrange this themselves and that I should come here.
The problems began around May/June of last year. Originally it would be minor ping spikes that were only tangible whilst gaming, and would only occur a couple of hours a week. However, over the following months, problems have become more persistent and have started to intermittently affect most areas of internet usage.
Problems/Symptoms
- Working - I work from home most days of the week. Occasionally when a ping spike occurs whilst working the virtual desktop will freeze. If the spike is too long or bad the connection to the desktop will end. At this point, I will have to restart the VPN and log in again.
- Streaming - When streaming live content e.g. sports or TV, live players such as Sky Go will intermittently pop up with a video player error (fixes upon re-open). This doesn't affect streaming platforms that can buffer such as Netflix or YouTube.
- Signing in to online accounts - sometimes when logging into websites like Netflix the log-in request will time out and we just have to keep trying till it eventually works.
- Online Gaming - hasn't been possible in months. Ping spikes are too frequent for fast-paced online gaming. Full disconnects are quite rare.
Broadband Quality Monitor
I think the ping spikes are visible in Broadband Quality Monitor below. Although they feel longer than 160 ms. When pinging using cmd to 8.8.8.8 I can see intermittent spikes up to 430ms and at worst in the 2000-3000ms mark.
My Broadband Ping
Logs have been posted separately in the replies below
House Broadband set up
I do have a switch set up inside my house that connects to the hub, which then feeds all devices (TVs inside the house.) However, these issues persist when the switch is disconnected and nothing is connected to the Superhub except one laptop connected by ethernet running ping/speed tests. (I've tried with just one device connected to the hub and problems persist on phone, laptop and computer)
Attempts at resolution so far
- I've tried upgrading my broadband contract from 500 Mbps to gig1.
- Two separate superhub 5s installed by Virgin Media technician and myself have had the same problem. (And an old super hub 3.)
- I bought a separate router to try running the superhub in modem mode to no effect. Including trying QOS.
- Virgin Media technician tried moving the superhub closer to the brown box to no effect.
- Countless superhub resets, and calls into the call centre where they have sent commands to my hub which haven't resolved the issue.
- I have had a private technician come in and investigate the switch/connections in the house to see if these could be causing the error. He is sure that the problem is outside the property.
Thanks for all your time and help. If there is any more information I can provide, please let me know. The problems have been more frequent and increasingly frustrating since about September so any help would be massively appreciated.
  • Logs part 1
    I'm not familiar with logs or technical details but tried to decipher the pinned "POWER LEVELS & SNR: A TECHNICAL PRIMER" message. I think I'm within acceptable power levels (might be wrong) however there are a lot of post-RS errors. These seem to consistently be in channel 14 although I have seen these in high numbers in channel 20 before. Virgin media technicians moved my hub yesterday closer to the brown box so post rs errors have reset and log values are shorter.
    3.0 Downstream channels
    Channel
    Frequency (Hz)
    Power (dBmV)
    SNR (dB)
    Modulation
    Channel ID
    1
    331000000
    6.4
    39
    QAM 256
    25
    2
    275000000
    4.4
    38
    QAM 256
    18
    3
    283000000
    4
    38
    QAM 256
    19
    4
    291000000
    4.6
    39
    QAM 256
    20
    5
    299000000
    4.9
    39
    QAM 256
    21
    6
    307000000
    5
    39
    QAM 256
    22
    7
    315000000
    5.3
    39
    QAM 256
    23
    8
    323000000
    6.1
    39
    QAM 256
    24
    9
    339000000
    6
    39
    QAM 256
    26
    10
    347000000
    5.4
    39
    QAM 256
    27
    11
    355000000
    5
    39
    QAM 256
    28
    12
    363000000
    5
    39
    QAM 256
    29
    13
    371000000
    5.5
    39
    QAM 256
    30
    14
    379000000
    6.2
    39
    QAM 256
    31
    15
    387000000
    6.3
    39
    QAM 256
    32
    16
    395000000
    6
    39
    QAM 256
    33
    17
    403000000
    5.4
    39
    QAM 256
    34
    18
    411000000
    5.2
    39
    QAM 256
    35
    19
    419000000
    5.1
    39
    QAM 256
    36
    20
    427000000
    5.1
    39
    QAM 256
    37
    21
    435000000
    4.9
    39
    QAM 256
    38
    22
    443000000
    4.8
    39
    QAM 256
    39
    23
    451000000
    4.9
    39
    QAM 256
    40
    24
    459000000
    5
    39
    QAM 256
    41
    25
    467000000
    4.9
    39
    QAM 256
    42
    26
    475000000
    5.1
    40
    QAM 256
    43
    27
    483000000
    4.9
    40
    QAM 256
    44
    28
    491000000
    4.9
    40
    QAM 256
    45
    29
    499000000
    4.5
    40
    QAM 256
    46
    30
    507000000
    4
    39
    QAM 256
    47
    31
    515000000
    3.7
    39
    QAM 256
    48
    Channel
    Locked Status
    RxMER (dB)
    Pre RS Errors
    Post RS Errors
    1
    Locked
    39
    13
    0
    2
    Locked
    38
    65
    0
    3
    Locked
    38
    78
    0
    4
    Locked
    39
    44
    0
    5
    Locked
    39
    12
    0
    6
    Locked
    39
    12
    0
    7
    Locked
    39
    19
    0
    8
    Locked
    39
    15
    0
    9
    Locked
    39
    17
    0
    10
    Locked
    39
    13
    0
    11
    Locked
    39
    5
    0
    12
    Locked
    39
    16
    0
    13
    Locked
    39
    12
    0
    14
    Locked
    39
    365
    195
    15
    Locked
    39
    9
    0
    16
    Locked
    39
    5
    0
    17
    Locked
    39
    8
    0
    18
    Locked
    39
    8
    0
    19
    Locked
    39
    7
    0
    20
    Locked
    39
    4
    0
    21
    Locked
    39
    4
    0
    22
    Locked
    39
    8
    0
    23
    Locked
    39
    7
    0
    24
    Locked
    39
    6
    0
    25
    Locked
    39
    7
    0
    26
    Locked
    40
    2
    0
    27
    Locked
    40
    3
    0
    28
    Locked
    40
    3
    0
    29
    Locked
    40
    4
    0
    30
    Locked
    39
    1
    0
    31
    Locked
    39
    4
    0
    3.1 Downstream channels
    Channel
    Channel Width (MHz)
    FFT Type
    Number of Active Subcarriers
    Modulation (Active Profile)
    First Active Subcarrier (Hz)
    159
    94
    4K
    1840
    QAM 4096
    1108
    Channel ID
    Locked Status
    RxMER Data (dB)
    PLC Power (dBmV)
    Corrected errors (Active Profile)
    Uncorrectable errors (Active Profile)
    159
    Locked
    40
    3.9
    2303509880
    0
  • Logs (part 1)
    Channel
    Frequency (Hz)
    Power (dBmV)
    SNR (dB)
    Modulation
    Channel ID
    1
    331000000
    6.4
    39
    QAM 256
    25
    2
    275000000
    4.4
    38
    QAM 256
    18
    3
    283000000
    4
    38
    QAM 256
    19
    4
    291000000
    4.6
    39
    QAM 256
    20
    5
    299000000
    4.9
    39
    QAM 256
    21
    6
    307000000
    5
    39
    QAM 256
    22
    7
    315000000
    5.3
    39
    QAM 256
    23
    8
    323000000
    6.1
    39
    QAM 256
    24
    9
    339000000
    6
    39
    QAM 256
    26
    10
    347000000
    5.4
    39
    QAM 256
    27
    11
    355000000
    5
    39
    QAM 256
    28
    12
    363000000
    5
    39
    QAM 256
    29
    13
    371000000
    5.5
    39
    QAM 256
    30
    14
    379000000
    6.2
    39
    QAM 256
    31
    15
    387000000
    6.3
    39
    QAM 256
    32
    16
    395000000
    6
    39
    QAM 256
    33
    17
    403000000
    5.4
    39
    QAM 256
    34
    18
    411000000
    5.2
    39
    QAM 256
    35
    19
    419000000
    5.1
    39
    QAM 256
    36
    20
    427000000
    5.1
    39
    QAM 256
    37
    21
    435000000
    4.9
    39
    QAM 256
    38
    22
    443000000
    4.8
    39
    QAM 256
    39
    23
    451000000
    4.9
    39
    QAM 256
    40
    24
    459000000
    5
    39
    QAM 256
    41
    25
    467000000
    4.9
    39
    QAM 256
    42
    26
    475000000
    5.1
    40
    QAM 256
    43
    27
    483000000
    4.9
    40
    QAM 256
    44
    28
    491000000
    4.9
    40
    QAM 256
    45
    29
    499000000
    4.5
    40
    QAM 256
    46
    30
    507000000
    4
    39
    QAM 256
    47
    31
    515000000
    3.7
    39
    QAM 256
    48
    Channel
    Locked Status
    RxMER (dB)
    Pre RS Errors
    Post RS Errors
    1
    Locked
    39
    13
    0
    2
    Locked
    38
    65
    0
    3
    Locked
    38
    78
    0
    4
    Locked
    39
    44
    0
    5
    Locked
    39
    12
    0
    6
    Locked
    39
    12
    0
    7
    Locked
    39
    19
    0
    8
    Locked
    39
    15
    0
    9
    Locked
    39
    17
    0
    10
    Locked
    39
    13
    0
    11
    Locked
    39
    5
    0
    12
    Locked
    39
    16
    0
    13
    Locked
    39
    12
    0
    14
    Locked
    39
    365
    195
    15
    Locked
    39
    9
    0
    16
    Locked
    39
    5
    0
    17
    Locked
    39
    8
    0
    18
    Locked
    39
    8
    0
    19
    Locked
    39
    7
    0
    20
    Locked
    39
    4
    0
    21
    Locked
    39
    4
    0
    22
    Locked
    39
    8
    0
    23
    Locked
    39
    7
    0
    24
    Locked
    39
    6
    0
    25
    Locked
    39
    7
    0
    26
    Locked
    40
    2
    0
    27
    Locked
    40
    3
    0
    28
    Locked
    40
    3
    0
    29
    Locked
    40
    4
    0
    30
    Locked
    39
    1
    0
    31
    Locked
    39
    4
    0
    Channel
    Channel Width (MHz)
    FFT Type
    159
    94
    4K
    1840
    QAM 4096
    1108
    Channel ID
    Locked Status
    RxMER Data (dB)
    PLC Power (dBmV)
    159
    Locked
    40
    3.9
    2303509880
    0
  • Logs (part 2)
    3.0 Upstream channels
    Channel
    Frequency (Hz)
    Power (dBmV)
    Symbol Rate (ksps)
    Modulation
    Channel ID
    0
    60300000
    42
    5120
    QAM 64
    1
    1
    53700000
    41.8
    5120
    QAM 64
    2
    2
    46200000
    40.5
    5120
    QAM 64
    3
    3
    39400000
    41
    5120
    QAM 64
    4
    4
    32600000
    40.8
    5120
    QAM 64
    5
    5
    23600000
    41
    5120
    QAM 64
    6
    Channel
    Channel Type
    T1 Timeouts
    T2 Timeouts
    T3 Timeouts
    T4 Timeouts
    0
    ATDMA
    0
    0
    0
    0
    1
    ATDMA
    0
    0
    0
    0
    2
    ATDMA
    0
    0
    0
    0
    3
    ATDMA
    0
    0
    0
    0
    4
    ATDMA
    0
    0
    0
    0
    5
    ATDMA
    0
    0
    0
    0
    Time
    Priority
    Description
    03-01-2024 14:04:28
    warning
    DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 14:04:28
    notice
    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:24:38
    notice
    CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:24:38
    notice
    CM-STATUS message sent. Event Type Code: 5; Chan ID: 18 19 20 21 22 23 24 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-Q
    03-01-2024 13:24:38
    notice
    CM-STATUS message sent. Event Type Code: 4; Chan ID: 18 19 22 23 26 27 30 31 34 35 38 39 42 43 46 47 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:24:38
    notice
    CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:24:38
    notice
    CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:24:25
    warning
    03-01-2024 13:24:21
    warning
    MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:24:14
    warning
    03-01-2024 13:24:14
    critical
    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:24:11
    critical
    03-01-2024 13:04:24
    notice
    REGISTRATION COMPLETE - Waiting for Operational status
    03-01-2024 13:04:19
    warning
    RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:04:19
    warning
    Dynamic Range Window violation
    03-01-2024 13:04:19
    warning
    03-01-2024 13:04:19
    warning
    03-01-2024 13:04:18
    warning
    RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:04:18
    warning
    REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:04:18
    warning
    03-01-2024 13:04:05
    warning
    DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 13:04:03
    notice
    Honoring MDD; IP provisioning mode = IPv4
    03-01-2024 13:03:48
    critical
    03-01-2024 13:03:47
    critical
    Cable Modem Reboot because of - HW or Power-On Reset
    03-01-2024 12:41:00
    critical
    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-01-2024 12:40:41
    critical
    03-01-2024 12:40:41
    critical
    03-01-2024 12:40:41
    critical
    03-01-2024 12:40:40
    critical
    03-01-2024 12:40:40
    critical
    03-01-2024 12:40:40
    critical
    03-01-2024 12:38:19
    critical
    • Sabrina_B's avatar
      Sabrina_B
      Hi PonniM 👋.
      Thanks for reaching out to us and welcome to the Community Forums. Apologies for the issues that you are having with your internet service. Could you please check all the settings on the Hub that you are in router mode, with Channel Optimisation is switched on, and any third party internet assisting devices have been removed, then restart the diagnostics again and post the results.
      Sabrina
      • PonniM's avatar
        PonniM
        Hi Sabrina!
        Thanks for your help. I’ve checked the hub settings and removed our wifi extender. I’ve reset the hub diagnostics. Will post updated diagnostics after the hub has had some time to collect data.
  • Have you found a solution?
    I’ve been having similar issues where I’m currently on 1GIG and my speed is all good but when I’m playing online videos games it’s laggy and delayed but the games network bar is not showing any spike or packet loss. But the network like keeps going thick and thin where it’s supposed to only stay thin.
    it’s been like for few weeks and when check the status in the hub , it’s been saying Intermittent issue and it’s been like this for a week now.
    today , I had a engineer come out and replace the wall equipments but nothing happened, same issue.
    so frustrating
    • John_GS's avatar
      John_GS
      Hi mm82286
      Thanks for posting and welcome to the community. Sorry to hear of any broadband issues.
      I can see from a system check you've booked another visit in, please let us know how this goes.
      Best wishes.
      • mm82286's avatar
        mm82286
        I waited 3 hours from 4pm to 7pm and unfortunately no one showed up.
        on the app , it still continues to say intermitten issue as it has for the past 2 weeks or so.
        very disappointed really.
  • jpeg1's avatar
    jpeg1
    Your Hub data is all good. The BQM shows a classic case of over-subscription on VM's local network. There's nothing that a technician can do for you except report this for attention at the network level. Will that will have any effect? You'll have to wait and see.
    • PonniM's avatar
      PonniM
      Thanks jpeg1. I believe the local area field manager is being notified. So hopefully they can resolve the issue.
  • Hello, just wanted to bring this back to the top. I've had Superhub 5 recently installed and I'm experiencing very similar issues. Did you ever find a solution to this?
    • Daniel_Et's avatar
      Daniel_Et
      Hi rafiali123 👋 Thank you for your post and welcome to the Virgin Media Community 😀
      We're sorry to hear you're experiencing similar issues 😔
      In order to discuss this matter with you, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
      Regards,
      Daniel
      It would have been better to start a new thread rather than append to a very long 2 year old thread.  You would have had better responses?
