on 28-12-2023 21:12
My virgin hub is showing a red light. It is cool to touch and is well ventilated also everything is working as it should, this forum recommends a new hub is required is this correct and if so how do I get one as I can’t get through on 150
Answered! Go to Answer
on 29-12-2023 08:21
Finally managed to get through to 150 they ran tests to say all is ok and that the red light is normal, I find this strange as VM guidance says it is a problem and this has never been on in the past
on 28-12-2023 21:18
Do you know what version of hub you have? Are you operating the hub in router or modem mode?
on 28-12-2023 21:26
hub 3 and using as router mode
on 29-12-2023 08:21
on 29-12-2023 08:42
Hi MalandBren75,
Thank you for your post. We are more than happy to look into this for you.
I will private message you now to confirm your details.
^Martin
on 29-12-2023 13:21
on 30-12-2023 12:51
on 07-02-2024 21:11
I have the same problem. Red light on hub, but was working - until now. It’s been on and off. I have reset the hub and now we lost internet completely.
on 07-02-2024 21:51
on 12-02-2024 09:14
Glad to hear a tech has come and fixed this for you.
If you need anything going forward you know where we are.
Matt - Forum Team
New around here?
