Hub 5x using own router
Guinness2023
Morning everyone.
I’m trying to connect my Asus TUF-AX6000 router to my Hub 5x and i’m getting double NAT issues.
Now i know that modem mode isn’t available yet but i’m wondering what is the best work around for the time being.
Would anybody with better networking skills than myself be able to shine any light?
Many Thanks.
20 REPLIES 20
Legend
To avoid double NAT use the Asus TUF-AX6000 in Access Point mode.
Guinness2023
Hi Client62,
Access point mode disables the QOS features of the Asus router which i want enabled preferably.
Is there a way i can have the Asus in Router mode and avoid the NAT issues?
Legend
General advice is for QoS to always be fully disabled on domestic grades of router.
The concern is QoS often provides a performance hit, that may not have been obvious on FTTC but with more than a 1Gb on tap from the Hub 5x the next complaint is VM is slow ...
@Guinness2023 wrote:
Hi Client62,
In a word, no.
Well, technically you could use a VPN on the Asus, however, it would slow down your overall speed.
double NAT and DMZ to your router as you wait for modem mode
handsomeinked
Up to speed
Random question I don't suppose you're able to get to  http://192.168.0.1/?page=modemmode Just wondering if it's just the menu item that has been disabled... Also, keeping an eye as FTTP is coming to our area, probably much later in the year as they are only just prepping the current ducting to blow the new fibre down to replace the coax. So, really don't want to make the move until modem mode is available as well, I like the way I have my network setup and don't want to struggle to achieve even the most basic of task with virgins' attempt at a router.
It’s always best to be positive but we all have crappy days.
VM Hub5 on Gig1, Etc etc
My Broadband Ping - Virgin Media Gig1
No, it does not work.
Is QOS really that important to you?
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
Or for more security if you don't trust VM NAT your own NAT
