Scotthopes
2 years agoJoining in
Hub 5 will not accept router password, even after reset
Using the VM connect app that never seems to work Ive turned my sons nintendo switch off from the WiFi.
When I went to reactivate it the VM connect app says hub not located. (seems to be a very common and frequent issue from what I've read on forums)
So I tried doing it from the hub settings instead. But when putting password in (not the WiFi password before anyone suggests that) it wouldn't accept it. So I hard reset the router and tried again. Still nothing on either the app or the hub accepting the password after the hard reset.
Is there anything else I can try.
Done the 60s reset
