- jpeg1Alessandro Volta
Just to check, have you done the reset correctly? After holding down the button, it's important not to turn off the power or disturb the Hub in any way. You have to leave it to restart in its own time. Make sure you are using the router password, not the WiFi one.
- percywOn our wavelength
Done all that, still can't access the hub after reset, using default password.
- Client62Alessandro Volta
Regardless of what VM may write, a 60 second press of the RESET button appears to be needed to trigger a VM Hub to begin the process of reverting to the shipping condition.
Yes there are mixed messages on the required time. I always use and suggest 60 seconds. Others seem to manage with less.
- legacy1Alessandro Volta
are you putting in Admin and not admin?
What message do you get in response to the password entry? Sounds like you may have a faulty Hub.
- Lee_R
Hi percyw thanks for posting and welcome back to our community.
Sorry to hear you've been unable to access your hub settings. I would like to take a look on your behalf. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
RegardsLee_R
but you have a hub 5 that shows a hub 3
do you have HomePlug - Network Via Mains?
Well you are certainly connecting to the Hub, since it's giving you a normal response apart from the password message. I would report the Hub as faulty, but I'm not sure how easy it would be to get a replacement.
- jbrennandVery Insightful Person
Are you running a VPN or - on an Apple device "private Relay" - if so you cant log in to the Hub settings - so switch it off and try again.
- Lee_R
Hi percyw, thanks for getting back to me privately.
This is just a quick note to confirm you're satisfied with the response and efforts of the forum team? Remember, if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand. Please bear in mind, you can manage your account from here. Your online account, will give you access to your bills, show your package details, diagnose any possible faults and monitor any orders and appointments you may have.
Lee_R
Very satisfied with all the help and assistance in an effort to resolve the issue.
Just for completion, the problem was resolved with trial and error with a malformed number on the hub label.
- Ashleigh_CForum Team (Retired)
Thank you so much for updating the thread percyw it's very much appreciated and we are glad that this has now been resolved.
Please do pop back to the forums in the future should you need any help and we will do all we can to advise.
For our education, how was control of the Hub menu regained ?
Related Content
- 1 year ago
- 2 years ago
- 7 months ago
- 1 year ago
