paul_m_n's avatar
paul_m_n
Hub 5 issues - speed
Hi - just upgraded from a hub 3 to hub 5 with 1 GB speed on Friday and had massive speed issues ever since.  Generally fine in the early mornings and evenings but grinding down to <5Mbps during the day and sometimes not working at all.  The hub 3 was working fine so it seems very odd.
Is anyone else having these speed issues with a hub 5 at the moment?
  • Tudor's avatar
    Unlikely to be the Hub5, if it was I would expect the problem to be constant.
    Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
    • paul_m_n's avatar
      paul_m_n
      I didn't ring that number but rang the general helpline and they're saying it's a known issue which is affecting 20% of hub 5 users only.  Other hubs aren't affected and it will take 24 hours to fix.  It just seems like a massive coincidence that as soon as I install a new hub then we have these issues.
    • paul_m_n's avatar
      paul_m_n
      Thanks for  the reply.  No it's not that.  I'm not that tech savvy and did plug an ethernet cable into the 2.5Gb port initially which connects to a TP-Link deco mesh system and we connect to the internet via that.  The problem persists though even if we connect directly the the hub via wifi and I've also now plugged the deco into a different port and it hasn't helped.  The speeds drop down to next to nothing (1-2 Mbps) between about 9.30am and 6pm but in the early morning and evening they're running at 200+ Mbps.
      • Daniel_Et's avatar
        Daniel_Et
        Hi paul_m_n, thank you for your posts.
        We're sorry to hear about the speed issues you're experiencing 😔
        I can see you've spoken to the team since your most recent post. Has a resolution been provided?
        Thank you for your support Tudor and Client62 👍
        Regards,
        Daniel
