- Client62Alessandro Volta
It can just be the LED colour is fading or it can an over temperature fault.
To check login in to the Hub 3 menu at http://192.168.0.1/ use the numeric HUB PASSWORD from the bottom side label. ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ? - wasp_manJoining in
Shows a few errors for WIFI and temperature says Normal.
- Matthew_ML
Hey wasp_man, thank you for reaching out and I am so sorry to hear about this.
I am going to send you a DM, but please can you try these steps for us;
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
Look out my for PM. Cheers
I am sure it was supposed to be replaced a couple of years ago and we never got a replacement. Had it about 8 years or more.
Related Content
- 4 months ago
- 3 months ago
- 1 year ago
- 2 years ago
