Lazytechnician's avatar
Lazytechnician
Constant red light on hub 3
Constant red light on hub 3, regular drop outs
Device is well ventilated and not warm to the touch
1 Reply
  • Hi Lazytechnician
    Have you done the below;
    •             Turn the power switch off on the back of the Hub.
    •             Ensure the Hub is upright, in a well-ventilated location and out of direct sunlight, if possible.
    •             Switch the hub back on at the power. The Hub should now operate normally.
    Keep me posted :).
