fayec202's avatar
fayec202
12 months ago
Constant Red light on hub 3
Soon after changing package my broadband is intermittent. Red light on hub 3 box, I’ve done all the checks steps, is well ventilated etc. I only ever end up with check back here in 24hours.
I’ve had the hub for 7 maybe 8 years, can someone please help me?
TV works fine.
  • Hey fayec202, thank you for reaching out and I am so sorry you are having some issues with a red light.
    Please do try these steps;
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
     And also look out in your DM's.
    • fayec202's avatar
      fayec202
      Matt I’ve done all that several times, over several weeks. Can you send me a new hub?
