casbar's avatar
casbar
Dialled in
Constant Red Light on Hub 3 and wi fi dropping
Wi Fi keeps dropping, have checked all cables, Reset Hub several times, tried virgin support on 150, couldn't speak to anyone, promised to send a link to my phone, which never arrived.
The hub is in exactly the same position it has been for 5 years with no issues, it has just started to show the red light and poor wi fi coverage.
What is the solution ๐Ÿ™‚
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
  • Thanks, just spent 30 mins talking to virgin media support. They told me to check the cables, then said the red light is nothing to worry about and they will monitor for 48 hours and get back to me. I explained I had reset the hub, which they could see, but still insisted the red light is nothing to worry about.
    • Daniel_Et's avatar
      Daniel_Et
      Hi casbar, thank you for your posts.
      We're sorry to hear about the problem you're having ๐Ÿ˜”
      In order to discuss this with you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
      Thank you for your support Adduxi ๐Ÿ‘
      Regards,
      Daniel
  • Thank you Daniel for all your help. Had a text that a replacement Hub is on its way
    Robert
