seshiroth's avatar
seshiroth
Just browsing
9 months ago
VRChat/RTSP issue with Hub 6
I've seen this referenced for the Hub 5 here: Hub 5 crashes from RTSP stream | Virgin Media Community - 5307855
and here: connection cuts out when on VRchat VR mode | Virgin Media Community - 5545744
I currently see this with a Hub 6 where if I join a world that has a stream playing (RTSP) it crashes. The only solution is to block the port 554, but that then leaves you unable to enjoy the streamed content.
Are there any other solutions other than going to another provider and router?
  • The HUB 6 is not available in England, so I'm unsure how much feedback you'd get here.
    • seshiroth's avatar
      seshiroth
      Just browsing
      Interesting, apparently the Hub 6 in Ireland is the Hub 5 in the UK /shrug
    In the UK we have SAGEMCOM HUB 5 (F3896LG-VMB) this is a DOCSIS / CATV device.
    Reports started of the VRCHAT/RSTP crashing UK Hub 5 that were operated in Router mode and on software version LG-RDK_4.6.24-2206.7 which was current in 2022. At the same time Sonos Wi-Fi was also mentioned as also being able to trigger a similar Hub 5 crash.
    Can we get the OEM model number and software version of the ROI Hub 6 for comparison ?
