Anonymous's avatar
Anonymous
12 months ago
Virgin Media SH3 Daily dropouts- RCS Partial Service/SYNC Timing Errors
We have been dealing with more and more dropouts and disconections which can last between 30 seconds to minutes or until the Superhub gets restarted either manually or by itself, I have tried multiple things including reset/power cycle and have even had VM engineers out last year in Dec 2023, when they visited they replaced an old Coax splitter and said it was all fine (obviously is not) in Sept to improve WiFi we got a third party router which I didn't expect to fix problems just to improve the WiFi end since but the issues got worse??? we have since taken the other router out the equation and put the SH3 back into Routing mode and genuinely I don't know what to do, I ran a test with an Ethernet cable going from the SH3 in Modem mode to my PC and we get the speeds paid for it just goes out all of the time, I need help.
Before you ask yes I have setup a BQM but its not very conclusive but I will post if you ask.
Setup:
Virgin Media Superhub 3 VM M250 package
Logs: (these are from days ago but they still happen daily)
Data:
11387500001.237256 qam1
2146750000137256 qam2
31547500000.938256 qam3
4162750000137256 qam4
51707500001.238256 qam5
6178750000138256 qam6
7186750000137256 qam7
81947500000.937256 qam8
9202750000138256 qam9
10210750000137256 qam10
112187500000.937256 qam11
122267500000.735256 qam12
132347500000.537256 qam13
142427500000.436256 qam14
152507500000.536256 qam15
162587500000.733256 qam16
17346750000037256 qam27
18354750000037256 qam28
19362750000-0.237256 qam29
20370750000-0.237256 qam30
21378750000-0.537256 qam31
22386750000-0.537256 qam32
23394750000-0.738256 qam33
24402750000-0.737256 qam34
1Locked37.310259726234020588
2Locked37.62417083997699879
3Locked38.61536571305734844
4Locked37.6213247764963850
5Locked38.62686313801560546
6Locked38.6866602412158353
7Locked37.6854895382132508
8Locked37.66189973959051
9Locked38.6208934867864560
10Locked37.61605365861729048
11Locked37.6125127361955905
12Locked35.72346397271428173
13Locked37.3118880120840005
14Locked36.3314571451297978
15Locked36.3223730811534751
16Locked33.8750403334143620
17Locked37.643323574177
18Locked37.642079566067
19Locked37.634890859392
20Locked37.633549055385
21Locked37.331984954933
22Locked37.634779751221
23Locked38.635367155523
24Locked37.633677351367
hannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
14960001449512064 qam1
23660011148512064 qam3
32359979547512016 qam9
43010012047.8512064 qam4
54309992648.5512064 qam2
1ATDMA0070
2ATDMA00130
3ATDMA00200
4ATDMA0050
5ATDMA0015
0
SFID50286
Max Traffic Rate287500061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID50285
Max Traffic Rate27500061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
  • Hey Henry9, thank you for reaching out and I am so sorry you are struggling with your connection.
    Let me send you a DM and we will check this out.
    The connection has logged tens of millions of Pre RS Errors & Post RS Errors
    • Anonymous's avatar
      Anonymous
      Ah I see, I'm not very aware when it comes to understanding that, time for an engineer visit again?
        Anonymous
        Update: narrowed the issue down to Coax connection somewhere, drops connection when moved.
