spudandbeanz's avatar
spudandbeanz
2 months ago
Upstream power too high?
I've been having connection drop-out issues for the past few months (~180 reconnects within the last month according to VM, though I only saw a drop 1-2 a day for 5-90 mins at a time). I'd been mostly away from home so didn't bother about it until this week, when VM sent out an engineer to investigate (10th July).
The engineer removed an old NTL attenuator/splitter, along with the splitter for the broadband and TV (as I plan to ditch the TV). He also switched out my Hub 3 for a Hub 5, which has an inline attenuator on its cable feed.
Annoyingly I didn't note the full line stats before the changes, but the engineer said the downstream was reporting as -8 dBmV, and after these changes is now 0 to -5 dBmV with an SNR of 40 dB.
I'm still having drop-outs (and T2 and T3 timeouts), though less frequent (1 time a day for 1-5 mins at a time), and from doing some research I suspect my upstream power is still too high. It's currently sitting at 52 dBmV, but I've seen it get as high as 59 dBmV immediately after the modem reconnected (it drops back down to 52 dBmV over a span of ~20 mins once the connection is back up).
I just wanted to confirm my understanding is correct before requesting another engineer visit to correct the upstream power.
I tried to add the full line stats and log into this post, but the forums report "Your post contains invalid HTML." if I do... that used to work.
  • I had a second engineer visit on Friday and he moved me to a different tap (and tap bank), which has brought all the values back into spec, given me 5 + 1 upstream channels, and also seems to have resolved the noise issue (though I did have a bunch of noise Friday night between 11pm-1am, but that may have just been maintenance; not seen it since).
    I do suspect there's still an issue with that cab given how regular the noise pattern was (basically every 12h like clockwork), but as it's no longer affecting my connection I can't get any more data on it.
    You mentioned an attenuator on the line to the Hub 5.  Is it still there ?
    If that is a Wideband attenuator, removing it would have the effect of causing the Downstream Power levels to increase, and the Upstream Power levels to decrease.
    Might be worth a try, you can re-instate the attenuator if there is no improvement.
  • spudandbeanz's avatar
    spudandbeanz
    I've been monitoring this since the engineer visit, and it seems there's two noticeable spikes between around 9am-noon and then again at 9-midnight. At this time I see my modem upstream power rise from 52 dBmV to 59 dBmV, and the QAM often drops to 32 or 16.
    This is also visible on the BQM before the engineer visit, though then it would always cause the connection to drop out entirely.
    It seems the service tracker saying "Intermittent signal in area" may not be a lie after all. Can anyone from Virgin comment on whether the networks team are aware of this?
    I can see it happening right now, as it's almost 10pm.
    • Martin_N's avatar
      Martin_N
      Thank you for keeping us updated with this spudandbeanz. We're sorry for the issue you're still having with the service.
      We can certainly take a further look into this. I will private message you now to confirm your details.
      ^Martin
        spudandbeanz
    There is only one 3.0 Upstream channel in the stats above,
    it is normal to have between four and six channels connected and all at QAM 64.
    Downstream Power Levels of -7 to +7 dBmV are preferred, +10dBmV is the max acceptable, with a SNR of 33dB or higher across all DOCSIS 3.0 channels. Rising error counts across many channels is a current service noise fault.
    Upstream
    Power Levels of 35 to 49 dBmV are preferred, with QAM 64 Modulation mode across four to six DOCSIS 3.0 channels.  Seeing QAM 32/16/QPSK is a current service noise fault.  Seeing less than four DOCSIS 3.0 channels is usually a signal level fault.
  • Anonymous's avatar
    Anonymous
    Firstly ”...180 reconnects within the last month according to VM”; yeah firstly ignore that, they have just made that figure up, means nothing.
    Now yes, your logs are a complete mess, so yes not surprised that your upstream power is at that level and also, really you only have one locked upstream channel?
    The way that it works is this, the hub increases the upstream power in an attempt to communicate with the CMTS (that’s the device which is ultimately at the other end of the cable). It keeps ramping up the power until either it gets a stable connection or it hits its upper limits (which oddly enough is 59 dBmV, after which it reboots).
    High upstream power is not a problem it itself which needs to be fixed, it's an indication that something else is wrong. Mostly likely a bad cable connection between your hub and the street cabinet, possibly also a faulty amp in said cabinet or an upstream cabinet.
    “....but the engineer said the downstream was reporting as -8 dBmV, and after these changes is now 0 to -5 dBmV with an SNR of 40 dB."
    Great, good, but irrelevant, you have a cable issue which is allowing noise ingress and killing your upstream connection. Sorry but, good luck getting VM to either understand or deal with it.
    • Nednats's avatar
      Nednats
      I’m seeing something very similar on my connection — high upstream power levels (often around 52 dBmV), T3/T4 timeouts, and DOCSIS 3.1 failing to hold a lock, falling back to 3.0.
      Unfortunately, I’ve also been going in circles with support. So far, Virgin Media have mostly pointed to internal wiring or suggested replacing the hub, even though logs clearly indicate upstream signal or CMTS-side issues. I’ve raised a complaint, shared BQM data and modem logs, and asked for escalation but getting beyond first-line troubleshooting has been a struggle.
      Has anyone here had success getting Virgin to actually investigate this properly, especially if the issue lies at the cabinet or further upstream?
      • Carley_S's avatar
        Carley_S
        Hi Nednats
        Sorry to hear of your service concerns. I can see that you've started your own thread and are being supported there. Should you've any further questions at all, please direct them to your already open thread, and we can support you from there.
      spudandbeanz
      I understand, though by "correct the upstream power" I really meant "fix whatever is causing the modem to have to shout so loud to be heard".
      Yes, and I've also seen that drop down to QAM 32 at times. I'm pretty sure I had 4 before these issues started.
        Anonymous
        "I understand, though by "correct the upstream power" I really meant "fix whatever is causing the modem to have to shout so loud to be heard”."
        Fine yes, you get it, alas some people who respond to similar threads, don’t necessarily do and just crash in with a generic ‘make a BQM’ (although oddly the people who request this, often don’t respond to what it says, almost as if they don't actually understand what they’ve asked for)!
        OK look you are not an idiot are you? Your upstream connection is shot, you have a really bad noise ingress, somewhere. Now the problem is getting VM to acknowledge this and deal with it.
  • legacy1's avatar
    The attenuator was likely need when the amp was working correctly removing a attenuator don't not fix this.
    spudandbeanz
    Apologies for the formatting below. It would only let me post it when pasted as plain text.
    3.0 Downstream channels
    Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
    1    306000000    -3.3    39    QAM 256    22
    2    138000000    0.8    41    QAM 256    1
    3    146000000    0.4    41    QAM 256    2
    4    154000000    0.1    40    QAM 256    3
    5    162000000    0.3    40    QAM 256    4
    6    170000000    0.5    40    QAM 256    5
    7    178000000    0.7    40    QAM 256    6
    8    186000000    -1.1    40    QAM 256    7
    9    194000000    -1.2    40    QAM 256    8
    10    202000000    -1.3    40    QAM 256    9
    11    210000000    -1.3    40    QAM 256    10
    12    218000000    -1.6    40    QAM 256    11
    13    226000000    -1.8    40    QAM 256    12
    14    234000000    -2.2    40    QAM 256    13
    15    242000000    -2    40    QAM 256    14
    16    250000000    -2    40    QAM 256    15
    17    258000000    -2.3    40    QAM 256    16
    18    266000000    -2.5    40    QAM 256    17
    19    274000000    -2.7    40    QAM 256    18
    20    282000000    -2.5    40    QAM 256    19
    21    290000000    -2.5    40    QAM 256    20
    22    298000000    -2.7    40    QAM 256    21
    23    314000000    -3.4    39    QAM 256    23
    24    322000000    -3.8    39    QAM 256    24
    25    330000000    -4    39    QAM 256    25
    26    338000000    -4    39    QAM 256    26
    27    346000000    -4.4    39    QAM 256    27
    28    354000000    -4.4    39    QAM 256    28
    29    362000000    -4.3    39    QAM 256    29
    30    370000000    -4.3    39    QAM 256    30
    31    378000000    -4.5    39    QAM 256    31
    32    386000000    -4.7    39    QAM 256    32
    Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
    1    Locked    39    71    0
    2    Locked    41    46    0
    3    Locked    41    60    5
    4    Locked    40    60    0
    5    Locked    40    65    0
    6    Locked    40    59    0
    7    Locked    40    45    0
    8    Locked    40    63    0
    9    Locked    40    37    0
    10    Locked    40    55    0
    11    Locked    40    46    0
    12    Locked    40    56    0
    13    Locked    40    58    0
    14    Locked    40    62    0
    15    Locked    40    64    0
    16    Locked    40    57    0
    17    Locked    40    64    0
    18    Locked    40    59    0
    19    Locked    40    58    0
    20    Locked    40    55    0
    21    Locked    40    71    0
    22    Locked    40    76    0
    23    Locked    39    77    0
    24    Locked    39    67    0
    25    Locked    39    59    0
    26    Locked    39    72    0
    27    Locked    39    68    0
    28    Locked    39    73    0
    29    Locked    39    89    0
    30    Locked    39    78    0
    31    Locked    39    77    0
    32    Locked    39    74    0
    3.1 Downstream channels
    Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
    159    92    4K    1800    QAM 4096    1128
    Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
    159    Locked    40    -4.7    3934885581    0
    3.0 Upstream channels
    Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
    0    36600000    51.8    5120    QAM 64    11
    Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
    0    ATDMA    0    4    0    0
    Time    Priority    Description
    13-07-2025 12:44:18    warning    DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=****;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:44:17    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:33:15    notice    REGISTRATION COMPLETE - Waiting for Operational status
    13-07-2025 12:33:10    warning    REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:33:04    notice    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:33:03    notice    TLV-11 - unrecognized OID;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:32:55    warning    DHCP WARNING - Non-critical field invalid in response ;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:32:53    notice    Honoring MDD; IP provisioning mode = IPv4
    13-07-2025 12:32:40    warning    ToD request sent - No Response received;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:32:40    critical    No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:32:30    warning    REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:32:25    notice    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:32:23    notice    TLV-11 - unrecognized OID;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:32:16    warning    DHCP WARNING - Non-critical field invalid in response ;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:32:14    notice    Honoring MDD; IP provisioning mode = IPv4
    13-07-2025 12:32:02    critical    Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    13-07-2025 12:31:35    warning    ToD request sent - No Response received;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:59:03    warning    DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:59:03    critical    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:48:20    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:48:00    notice    REGISTRATION COMPLETE - Waiting for Operational status
    12-07-2025 09:47:54    warning    REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:47:48    notice    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:47:47    notice    TLV-11 - unrecognized OID;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:47:38    warning    DHCP WARNING - Non-critical field invalid in response ;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:47:36    notice    Honoring MDD; IP provisioning mode = IPv4
    12-07-2025 09:46:59    critical    Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:46:56    critical    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:46:10    critical    Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=****;CMTS-MAC=****:cd;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:45:39    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:45:38    warning    Lost MDD Timeout;CM-MAC=****;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
    12-07-2025 09:45:27    critical    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=****;CMTS-MAC=****;CM-QOS=1.1;CM-VER=3.1;
    • Cardiffman282's avatar
      Cardiffman282
      Community elder
      The upstream power level is too high but more importantly you only seem to have one upstream channel. Is that correct?
      Also check for local faults on 0800 561 0061.
        spudandbeanz
        One channel is indeed what the router shows. This is a M125 connection FWIW.
        The online fault checker has just been switching between "There is intermittent signal in your area" and "We need to send an engineer" for the past few months, though now it says "No broadband issues found".
        Given this connection had been stable for years, and given nothing changed on my side, I do suspect I got moved to a different tap or something a few months back.
