Sandman261's avatar
Sandman261
Regular dropped packets while gaming & T3 timeout errors
Hi all,
Hoping I can get some help here as I have tried to use the online service checker and keep getting sent round in circles with rebooting the hub / factory resetting which hasn't resolved the issue.
We have recently moved into this house a couple months back and since the install been receiving on and off issues with the stability of the network which is affecting working from home and online gaming. It will be fine for a few days then we will start seeing dropped packets / packet burst in gaming. When working from home this also kicks off the remote desktop sessions I use.
Since this has started getting more frequent I have set up a BQM graph and hopefully the links below will work:
26th:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/8e0e268fee776ef7500c7d2376ceba20625b96c8-26-06-2024
27th:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a47b50c4e9688abef5cf89e9bb5f36567846ca82-27-06-2024
Also logs from the hub - I have been keeping an eye on the number of timeouts and this seems to have reset recently as a couple days ago looked like this:
If you need any more information let me know! Thanks.
27-06-2024 13:34:48criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-06-2024 11:09:16errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-06-2024 09:47:56critical16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-06-2024 09:47:56criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-06-2024 09:46:48criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-06-2024 02:54:04noticeREGISTRATION COMPLETE - Waiting for Operational status
25-06-2024 02:54:01noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-06-2024 02:53:55noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-06-2024 02:53:52noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-06-2024 02:53:50warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-06-2024 02:53:47noticeHonoring MDD; IP provisioning mode = IPv4
25-06-2024 02:53:39criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-06-2024 02:53:38criticalCable Modem Reboot because of - Software_Upgrade
25-06-2024 02:51:36alertSW download Successful - Via Config file
25-06-2024 02:48:41alertSW Download INIT - Via Config file cmreg-vmdg660-bbt076-b.cm
25-06-2024 02:48:03criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-06-2024 02:48:03criticalCable Modem Reboot because of - unknown
20-06-2024 15:37:11criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
19-06-2024 14:21:13criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-06-2024 14:54:51criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-06-2024 14:17:54criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-06-2024 14:17:54critical16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-06-2024 14:16:46criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-06-2024 13:29:20criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-06-2024 06:57:10criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
07-06-2024 15:36:07criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
07-06-2024 11:17:57criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-06-2024 17:29:28criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-06-2024 06:10:19criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-06-2024 12:37:13criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-05-2024 05:18:03criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-05-2024 02:50:48criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
3.0 Downstream channels
13310000006.241QAM 25625
21470000006.940QAM 2562
3155000000740QAM 2563
41630000007.540QAM 2564
51710000007.241QAM 2565
61790000006.841QAM 2566
71870000006.641QAM 2567
8195000000741QAM 2568
92030000006.840QAM 2569
10211000000741QAM 25610
112190000006.240QAM 25611
122270000006.140QAM 25612
132350000006.540QAM 25613
142430000006.840QAM 25614
152510000006.340QAM 25615
162590000006.440QAM 25616
172670000007.341QAM 25617
182750000007.541QAM 25618
192830000006.841QAM 25619
202910000007.141QAM 25620
212990000007.441QAM 25621
22307000000741QAM 25622
233150000006.241QAM 25623
243230000006.141QAM 25624
253390000006.741QAM 25626
263470000006.741QAM 25627
273550000006.241QAM 25628
283630000005.841QAM 25629
293710000006.441QAM 25630
303790000006.541QAM 25631
313870000005.841QAM 25632
1Locked41180
2Locked4090
3Locked4090
4Locked4060
5Locked4140
6Locked4160
7Locked4130
8Locked4140
9Locked4010
10Locked4140
11Locked4080
12Locked4080
13Locked40110
14Locked40130
15Locked40100
16Locked40120
17Locked4190
18Locked4180
19Locked4160
20Locked41110
21Locked41100
22Locked41160
23Locked41260
24Locked41130
25Locked41190
26Locked41190
27Locked41220
28Locked41290
29Locked41240
30Locked41330
31Locked41360
3.1 Downstream channels
33944K1840QAM 40961108
33Locked39-2.627562180669
3.0 Upstream channels
04960000045.35120QAM 641
14310000045.85120QAM 642
23660000045.55120QAM 643
33010000045.55120QAM 644
423600000465120QAM 645
0ATDMA0000
3ATDMA0060
4ATDMA0000
3.1 Upstream channels
610.441.02KQAM 256
6OFDMA20874000000180
    • Sandman261's avatar
      Sandman261
      Thanks for the info - no faults reported on that number when I called.
      I can't seem to run that speed test as it says it's not available on my network.
  • 3.0 Downstream channels
    13310000005.541QAM 25625
    21470000006.140QAM 2562
    31550000006.340QAM 2563
    41630000006.840QAM 2564
    51710000006.541QAM 2565
    61790000006.140QAM 2566
    71870000005.940QAM 2567
    81950000006.341QAM 2568
    9203000000640QAM 2569
    102110000006.340QAM 25610
    112190000005.540QAM 25611
    122270000005.340QAM 25612
    132350000005.740QAM 25613
    14243000000640QAM 25614
    152510000005.540QAM 25615
    162590000005.640QAM 25616
    172670000006.541QAM 25617
    182750000006.741QAM 25618
    19283000000640QAM 25619
    202910000006.441QAM 25620
    212990000006.741QAM 25621
    223070000006.341QAM 25622
    233150000005.541QAM 25623
    243230000005.441QAM 25624
    25339000000641QAM 25626
    263470000005.941QAM 25627
    273550000005.541QAM 25628
    283630000005.141QAM 25629
    293710000005.741QAM 25630
    303790000005.841QAM 25631
    313870000005.141QAM 25632
    1Locked41220
    2Locked40150
    3Locked40110
    4Locked40100
    5Locked4150
    6Locked40110
    7Locked4030
    8Locked4170
    9Locked4020
    10Locked4070
    11Locked40130
    12Locked40100
    13Locked40150
    14Locked40150
    15Locked40110
    16Locked40140
    17Locked41100
    18Locked41100
    19Locked40120
    20Locked41170
    21Locked41190
    22Locked41170
    23Locked41280
    24Locked41220
    25Locked41190
    26Locked41210
    27Locked41280
    28Locked41360
    29Locked41280
    30Locked41360
    31Locked41410
    33Locked39-3.031572114239
    04960000044.85120QAM 161
    14310000045.85120QAM 162
    23660000045.35120QAM 163
    33010000045.35120QAM 164
    423600000465120QAM 165
    0ATDMA0010
    1ATDMA0010
    2ATDMA0010
    3ATDMA0070
    4ATDMA0020
    610.441.02KQAM 256
    BQM:
    • Tom_W1's avatar
      Tom_W1
      Hi Sandman261 thanks for your post here although we're sorry to hear of the concerns you've raised.
      We've ran some checks on our line and there aren't any issues currently on the line and all the power levels are within the specifications we'd expect to see.
      How have things been over the last few days, are you still experiencing any problems?
      Many thanks
        Sandman261
        Hi Tom,
        Thanks for your response - It did improve after my last post and seemed to be ok over the weekend but this morning I had some disconnections while working and when checking I can still see T3 timeouts increase on the upstream page.
        I'm not sure if it's related but the hub logs are now showing a lot of "US profile assignment change"
        01-07-2024 12:42:25noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 12:02:56noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:48:09noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:48:00noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:42:57noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:42:21noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:37:18noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:36:52noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:31:49noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:31:10noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:26:07noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:25:17noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:20:14noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:20:10noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:15:07noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:14:37noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 11:09:34noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 03:38:44noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        01-07-2024 03:33:41noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 23:56:42noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 21:49:05noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 21:47:46noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 21:42:43noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 21:42:39noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 21:37:35noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 21:19:57noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 21:14:54noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        30-06-2024 09:49:29errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        29-06-2024 15:54:57criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        29-06-2024 13:54:45noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        29-06-2024 12:50:56noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        29-06-2024 12:32:39noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
        0ATDMA0030
        1ATDMA0020
        2ATDMA0020
        3ATDMA0070
        4ATDMA0030
        610.441.02KQAM 256
  • Just to update -
    Tonight is particularly bad and upload speeds have slowed to a crawl:
    27-06-2024 18:57:29
    27-06-2024 18:22:38noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 17:53:40criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 17:14:41noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 16:35:54noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 16:18:41noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 15:43:05noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 15:42:32noticeGUI Login Status - Login Success from LAN interface
    27-06-2024 15:38:02noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 15:37:50noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 15:32:47noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 15:11:35noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 15:06:32noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 15:03:30noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    27-06-2024 14:58:27noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
