Jon-J's avatar
Jon-J
Dialled in
Regular drops in speed and repeated router reboots
I've been having issues with my broadband speed for about a week now. I'm on Gig1 full fibe, with a Hub 4 router, and regularly get 950-985 Mbps download and about 100 Mbps upload.
On 5 Sept, I began to notice that webpages were loading incredibly slow, and performed a speed test. The download speed had dropped to 12.88 Mbps, but the upload speed was 104.80 Mbps. I turned the router off, and unplugged it for a few minutes, then plugged it back in. After a while I did another speed test and it was 945.93 and 104.88 Mbps.
I had the same problem yesterday, 10 Sept, with speeds of 0.91 Mbps and 102.43 Mbps. Again, after cycling the router, speeds were 945.98 and 104.89 Mbps.
The same problem then hit today, so bad that I couldn't even get speed test page to load. I tried to access the Internet through the Hub 4 router on both desktop (via Ethernet), and on mobile (via WiFi). Both encountered same issue. I finally got the speed test to work on my mobile, which registered 0.10 Mbps download.
I then tried logging into my account through the My Virgin Media app. When I tried to move on from the email login page I got a "Sorry, something's gone wrong" page, with the error code: FSB50. I was able to login to the router (192.168.0.1) and ran the Network Diagnostic Tool, but all this said was that "Your home network has a few problems", without giving further details.
I've had to access My Virgin Media account through mobile data. I ran through a Service status check and received an error for broadband, with an "Intermittent signal in your area" message.
After repeating the same routine (cycling the router), the problem was fixed - to a point. unfortunately, I'm getting 1/2 my download speed, at 437.49 Mbps, while the upload speed is consistent at 104.84 Mbps.
Is it the signal itself, or the Hub 4 router? I can't be expected to repeatedly cycle the router if this is going to be a regular occurrence.
5 Sept 2024
10 Sept 2024
11 Sept 2024
  • The preferred Power levels for the 3.1 Downstream  are -7 to +7 dBmV
    Here the figure is -14.6 dBmV, as this is a logarithmic scale, the received signal is a tiny fraction of what is expected,
    this is likely the root cause of your variable speed issues.
    You can try to request an engineer to be sent to rectify this, but I'd not be surprised if this turns out to be a fault in a street cabinet or even further back in the network that is affecting many customers in your locality.
    3.1 Downstream channels
    159Locked29-14.61129985351297
  • jbrennand's avatar
    Lets see the connection data - see this...
    Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
    • Jon-J's avatar
      Jon-J
      Dialled in
      3.0 Upstream channels
      14960000041.7705995120 KSym/sec64QAM1
      22360000040.2705995120 KSym/sec64QAM5
      33010000041.2705995120 KSym/sec64QAM4
      43660000041.2705995120 KSym/sec64QAM3
      54310000041.2705995120 KSym/sec64QAM2
      1US_TYPE_ATDMA0000
      2US_TYPE_ATDMA0000
      3US_TYPE_ATDMA0000
      4US_TYPE_ATDMA0000
      5US_TYPE_ATDMA0000
      3.1 Upstream channels
      610.044.02KQAM128
      6OFDMA20053.900
  • Jon-J's avatar
    Jon-J
    Dialled in
    part 2 of 2
    Time
    Priority
    Description
    Wed Sep
    11
    6
    CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Wed Sep
    11
    6
    US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Wed Sep
    11
    5
    DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Wed Sep
    11
    6
    Wed Sep
    11
    6
    CMSTATUS:US_Diplexer_Mode_Change_Ignore: (TLV-9) , (5-85) ;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Wed Sep
    11
    5
    MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Wed Sep
    11
    6
    CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Wed Sep
    11
    6
    Wed Sep
    11
    5
    Wed Sep
    11
    6
    Wed Sep
    11
    5
    Tue Sep
    10
    6
    Tue Sep
    10
    6
    Tue Sep
    10
    5
    Tue Sep
    10
    6
    Tue Sep
    10
    5
    Tue Sep
    10
    3
    No Ranging Response received - T3 time-out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Tue Sep
    10
    6
    Tue Sep
    10
    6
    Tue Sep
    10
    5
    Tue Sep
    10
    6
    Tue Sep
    10
    5
    Mon Sep
    3
    Mon Sep
    6
    CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Mon Sep
    6
    Mon Sep
    5
    Mon Sep
    6
    Mon Sep
    5
    Sun Sep
    6
    Sun Sep
    3
    Sun Sep
    5
    Sun Sep
    3
    Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Sun Sep
    3
    Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    3
    Sun Sep
    5
    TCS Partial Service;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.1;
  • Jon-J's avatar
    Jon-J
    Dialled in
    3.0 Downstream channels
    253310000008.00000036.386890QAM25625
    11390000008.50000031.403784QAM2561
    21470000008.40000231.688669QAM2562
    31550000008.40000231.993563QAM2563
    41630000008.09999832.237156QAM2564
    51710000007.80000332.237156QAM2565
    61790000007.69999732.676208QAM2566
    71870000007.90000232.676208QAM2567
    81950000007.59999832.676208QAM2568
    92030000007.30000332.962662QAM2569
    102110000007.19999733.062504QAM25610
    112190000007.50000033.376591QAM25611
    122270000007.40000233.486542QAM25612
    132350000007.19999733.834164QAM25613
    142430000007.00000033.834164QAM25614
    152510000007.50000033.486542QAM25615
    162590000008.09999834.925610QAM25616
    172670000008.30000335.595078QAM25617
    182750000008.69999735.595078QAM25618
    192830000008.69999735.595078QAM25619
    202910000008.50000035.595078QAM25620
    212990000007.69999735.595078QAM25621
    223070000007.19999735.779911QAM25622
    233150000007.19999735.779911QAM25623
    243230000007.50000036.609653QAM25624
    263390000007.90000236.386890QAM25626
    273470000007.69999736.386890QAM25627
    283550000007.50000036.386890QAM25628
    293630000007.09999835.779911QAM25629
    303710000006.90000235.595078QAM25630
    313790000006.90000235.595078QAM25631
    323870000006.80000336.386890QAM25632
    25Locked36.38689000
    1Locked31.40378400
    2Locked31.68866900
    3Locked31.99356300
    4Locked32.23715600
    5Locked32.23715600
    6Locked32.67620800
    7Locked32.67620800
    8Locked32.67620800
    9Locked32.96266200
    10Locked33.06250400
    11Locked33.37659100
    12Locked33.48654200
    13Locked33.83416400
    14Locked33.83416400
    15Locked33.48654200
    16Locked34.92561000
    17Locked35.59507800
    18Locked35.59507800
    19Locked35.59507800
    20Locked35.59507800
    21Locked35.59507800
    22Locked35.77991100
    23Locked35.77991100
    24Locked36.60965300
    26Locked36.38689000
    27Locked36.38689000
    28Locked36.38689000
    29Locked35.77991100
    30Locked35.59507800
    31Locked35.59507800
    32Locked36.38689000
    159964K1840QAM1024759
    Although the Downstream power levels are strong, the SNR ratio is close to or at the lower limits.
    Is there a known service fault in your locality - (do try both) ?
    Call 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
    Speed test the service to a Router mode Hub(3/4/5) + your device with the link below.
    Once the test begins click on: Run full test to include: Latency, Jitter, Packet loss & Upload speed
    The speed at the Hub should reflect your subscription
    • Jon-J's avatar
      Jon-J
      Dialled in
      The automated number indicated that there were NO issues in the area. Confusingly, following the VM link, it stated that there was an "Intermittent signal in your area. We’re looking into it. Check back here after 21 hours, and if there’s still an issue we’ll help you book an engineer."
      This was the result using the check VM speed test tool.
      Latency 16.7 ms
      Jitter 0.52 ms
      Download 74.0 Mbps
      Upload 103 Mbps
      Do I wait nearly 24-hours, or book an engineer? This has been ongoing for nearly a week.
  • Jon-J's avatar
    Jon-J
    Dialled in
    Thank you for this.
    I think I'll wait until tomorrow. If I'm still having problems then, I'll book an engineer.
  • Jon-J's avatar
    Jon-J
    Dialled in
    Is this what you're looking for, or do you require a link?
  • Jon-J's avatar
    Jon-J
    Dialled in
    I've been checking download speeds throughout the day and, while I haven't noticed any major drops like I've had over the past week, the download speed has been fluctuating - the lowest today being 489 Mbps, and the highest 845 Mbps. Apart from the highest reading, it's been holding around 500 Mbps, so just over almost half the speed I should be getting.
    Just ran https://www.virginmedia.com/help/check/status/identification/identify again and it said to book an engineer, so I set one up for Sat.
    Cheers for the help.
