Jon-J
5 months agoDialled in
Regular drops in speed and repeated router reboots
I've been having issues with my broadband speed for about a week now. I'm on Gig1 full fibe, with a Hub 4 router, and regularly get 950-985 Mbps download and about 100 Mbps upload. On 5 Sept, I bega...
- 5 months ago
The preferred Power levels for the 3.1 Downstream are -7 to +7 dBmV
Here the figure is -14.6 dBmV, as this is a logarithmic scale, the received signal is a tiny fraction of what is expected,
this is likely the root cause of your variable speed issues.
You can try to request an engineer to be sent to rectify this, but I'd not be surprised if this turns out to be a fault in a street cabinet or even further back in the network that is affecting many customers in your locality.
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159 Locked 29 -14.6 112998535 1297
