Jland's avatar
Jland
Just joined
9 hours ago
Red light
Iv got the red led on my hub 3.0 Iv tried un plugging and plugging back in and Iv recycled power many times, is there anything else I can do about this?
1 Reply
    If you are in modem mode and using a third party router then the light should be magenta (can also appear red) so there's nothing to worry about.
    However if you're in normal router mode and have performed the pinhole reset (keeping the reset button depressed for a full minute) and the lights still red then it should be replaced.
    A member of the forum team should pick this up for you in a day or two.
