Farrelly's avatar
Farrelly
Red Light on Virginmedia Hub
I have a solid red light on my VM hub, I see from other posts that this requires a replacement.
Can this be organised for me please.
Thank you.
  • Daniel_Et's avatar
    Daniel_Et
    Hi Farrelly, thank you for your post.
    In the first instance, please follow the below steps in the following order:
    • Turn the power switch off on the back of the Hub
    • Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
    • Use the power switch to turn the unit back on
    If after following the steps the router doesn't boot back up after a few minutes, or the red light returns when it does, it'll need replacing.
    Regards,
    Daniel
    • Farrelly's avatar
      Farrelly
      I've already rebooted twice, light is still red.
      Please advise on next step
        Daniel_Et
        Hi Farrelly, thank you for your response.
        In order to discuss this further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
        Regards,
        Daniel
