Bluemerle21's avatar
Bluemerle21
Red light on Virgin hub 3.0
The light that should be white is now a steady red. If I go to on line support the hub seems to pass the Virgin diagnostics. At that point if I ring support the automated system runs the diagnostics again. As the system passes I am cut off and sent a text link to a page that says error 404. Hopeless.
  • Hello Bluemerle21
    Sorry to hear of the Hub issues and the red LED showing, we appreciate you raising this with us via the forums and welcome to the community.
    The red LED can indicate overheating but can also be a faulty LED within the Hub. We're keen to get this looked into and I will send you a Private Message, please keep an eye out in the top right when signed into the forums for the envelope. This is where you will be able to find my Private Message and be able to respond.
    In the meantime please follow these steps and ensure if the Hub does feel hot touch it isn't used when no one is around to prevent possible issues:
    • Ensure the Hub is upright, in a well-ventilated location and out of direct sunlight, if possible.
    • Switch the hub back on at the power. The Hub should now operate normally.
    • Bluemerle21's avatar
      Bluemerle21
      An engineer has been to replace the hub.
      All good now - thanks
      • Sabrina_B's avatar
        Sabrina_B
        Amazing, thanks for the update on this. Should you need us again, please do reach back out to us 🙂.
