Craigfriz's avatar
Craigfriz
Settling in
10 months ago
Red light on hub
I have a solid red light on my virgin media hub 3 for over 6 months. (The hub is over 8 years old I believe) I’ve also been having issues with my WiFi dropping on a regular basis. I have connected virgin media and I have done a reset of the wifi router recently and have taken out the wires and plugged them in again. They sent me out a new power lead as they said this would resolve the issue, Unfortunately the red light is still coming up as a solid light light and the internet drips out on my devices from time to time.
  • Tudor's avatar
    Do a pin-hole reset and if the red LED persists then the hub will be replaced.
        The red LED on a Hub 3 is the overheating warning.  If this is faulty, i.e. on when it should be off, then the Hub needs replaced as it's a risk.  If you wait here a day or two a VM Mod will pick this up and discuss with you directly.
  • I believe VM are swapping H3s for H5s .. a straight swap .. I swapped mine and the difference is noticeable .. ring 150 after 0800 hrs .. you have had your moneys worth out of that H3 .. 8 yrs old .. 6 months iffy appearance .. good luck
      Hub 3 is still on the VM list of kit. They are used on Tiers up to 500 Mb.
