Sappy84
1 year agoJoining in
Red Light on hub
Appeared this morning and is solid hub feels a little warm but not hot?
If this is a Hub 3, and the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
