Brettalt's avatar
Brettalt
Red Light on Hub
My internet is working, but I've had red Light on router for some time now. I have tried everything: Turn off, Reset, check all connections etc and nothing has fixed.
Can I please have a new hub?
  • If it's a red light in Router mode as opposed to modem mode - VM need to swap out the hub asap as it is either overheating or thinks it is due to a faulty sensor!
    If it were me, I'd call 150 (or 0345 454 1111) and tell them it is hot - they'll book a tech visit sharpish!
    It is sad that offshore CS will only budge on this if you tell them it is hot - but unfortunately until proper training filters down - this is all we've got!
  • lotharmat's avatar
    lotharmat
    Community elder
    • Brettalt's avatar
      Brettalt
      Cheers for the advice lotharmat, appreciate it!
      • Natalie_L's avatar
        Natalie_L
        Hi Brettalt,
        Welcome to the community and thank you for posting.
        I am sorry to hear you are experiencing an issue with a red light showing on your Hub, we will do all we can to help.
        To look in to this further, I am going to pop you over a private message to take a few details.
        This will be available via the purple envelope on the top right of this page.
        Speak soon,
  • jbrennand's avatar
    start your own new thread - say what Hub model you have
