mb16's avatar
mb16
Red light on hub and warm
My hub has a constant red light and is warm to the touch.
I see some other posts here saying I might need a replacement.
Please let me know if a new one is needed.
  • Carley_S's avatar
    Carley_S
    Hi mb16
    Welcome to the community forums
    Sorry to hear of your concern with the red light warning on the hub.
    Sometimes this can be just an LED error on the hub rather than anything more, to test this can you please try a 60 second pin hole reset on the router. This will revert any customisations back to factory settings and full update the router with firmware/software updates. Please do not reboot the router whilst it is completing the pin hole request.
    Let us know if the light remains red after this pin hole reset and we'll assist further.
    • mb16's avatar
      mb16
      We tried to reset it but same issue. The red light has been showing for past two weeks.
      What are the next steps?
      • David_Bn's avatar
        David_Bn
        Thanks for coming back to us mb16, thanks for confirming that the reset has been attempted.
        I'd be happy to have this looked into, which will result in the hub being replaced, due to the nature of the fault.
        Check out the envelope in the top right hand corner for a private message from me
        David_Bn
