DJW13's avatar
DJW13
5 months ago
Red light on Hub 3
This came on a couple of days ago. I've tried switching off and on again and resetting. I even left it off overnight but the red light is still on. The box doesn't feel particularly warm but I have been unable to run diagnostics. Yesterday it didn't recognise the password, today I can get in and start running diagnostics but after it reaches 30% it throws me out and wants the password again then when I can start running the diagnostics again.
I would be pleased to hear and try any other suggestions - everything seems to be working OK and I could live with a red light instead of a green one unless it means that it is actually over-heating and could burst into flames!
  • The red light light is a known fault in ageing Hub3's (search this board) - its due to "failing" LED's and any issues you have will not be related to that.
    However it does mean that the overheating warning sytem onthe Hub is compromised - so VM will replace the Hub for you when they get here - probably with a second hand ageing Hub3 !
  • jbrennand's avatar
  • Hi DJW13,
    Thank you for your post and welcome to the community.
    We're sorry to hear about the red light on your hub.
    We can certainly look into this. I will private message you now to confirm your details.
    ^Martin
