staceymo
7 months agoJoining in
Red light on Hub 3
My superhub 3 is showing a red light, I've tried unplugging it for an hour and resetting it, but its still red. Everything seems to be working OK, should I be worried?
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly.
If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
