Steveb_bb
8 months agoJoining in
Red light on Hub 3
I've had a red light on my hub for about a month. After speaking to the support and doing all the usual things they ask you, turn it off, reset the hub, check the wires are connected etc. It still stays on from the moment you switch it on.
Was told by support this isn't fault, it's stand by?
Thanks for reaching out to us Steveb_bb, and welcome back to our Community Forums!
Sorry to hear of the solid red light on you hub currently.
The solid red light would symbolise either overheating, a fault LED light or potentially operating in modem mode.
Check out the envelope in the top right hand corner and providing you're not operating in modem mode, we will take the precaution and look to issue you with a like for like replacement hub.
David_Bn
