Readers's avatar
Readers
Red light on Hub 3
We’ve got the dreaded red light on our Hub 3, meaning WiFi dropping off and poor reception across the house. We’ve tried resets etc… but no joy. Can VM send a new hub please
  • If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
  • Zach_R's avatar
    Zach_R
    Hi Readers,
    I'm so sorry to hear that you're having some trouble with your Hub 3 displaying a red light along with connection issues. If you haven't done so already, please follow each of the below steps.
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If after following the above steps the router doesn't boot back up after a few minutes, or the red light returns when it does, then please respond to the private message that I'll be sending your way shortly and we can assist you further from there.
