DarrenandMagda's avatar
DarrenandMagda
Red light on hub 3
Hi all,
Like many previous posts, the LED that normally shows as white in our hub 3 is now red.  We've followed the guidance on these forums, restarted the hub and ensured that it is in a well ventilated place, but even after restarting the hub the once white LED remains red.
It is warm to the touch, but not hot.
Please could someone advise?
  • Hey DarrenandMagda, thank you for reaching out and a warm welcome to the community I am sorry to hear this.
    I am going to send you a PM but in the meanwhile please can you try these steps;
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
  • Hi Matt, thanks for this and we have responded to the PM.  We have already tried what you have suggested on a number of occasions and the Hub light remains red.
