Lindawhite14's avatar
Lindawhite14
Red Light on Hub 3
My hub 3 is showing a red power light instead of the usual white power light. It is solid red and the top half is warm to the touch.  I have seen that this means it needs replacing.  Any advice?
  • Reece_MH's avatar
    Reece_MH
    Thanks for trying a factory reset, Lindawhite14 - I'm sorry things are still the same.
    I'm going to send you a private message, to assist further with this, as we will need to book a Technician visit. Please look out for it in the top-right, white envelope or by tapping your profile picture, and selecting "Messages".
  • Kain_W's avatar
    Kain_W
    Hi Lindawhite14,
    Thanks for your post and welcome to the community.
    Sincere apologies for the issues faced with your Hub, can we ask firstly have you performed a pin hole reset.
    Also where is the box located?
    Let us know,
  • Thanks for coming back promptly.  Yes we have done a pin hole reset twice.  It is placed in an open position with plenty of air circulation.
    • Reece_MH's avatar
      Reece_MH
