1 Reply
- Ashleigh_CForum Team (Retired)
Hi there MarianaKonstant
I am so sorry to hear that you are facing this issue with a red light on your Hub. Can I ask if you have tried a pin hole reset? To do this push a pen etc into the reset hole and hold in for 30 seconds, this will cause a full factory reset so if you have changed any details such as the WiFi password at all then this will change to the original but you can reset this afterwards.
Related Content
- 2 years ago
- 3 years ago
- 5 years ago
- 7 months ago
- 1 year ago
