bdw's avatar
bdw
Superfast
12 months ago
Re: Hub 3 constant red light
I have the same issue as Joeycag. The indicator light changed to orange then red. It has gone back to orange again. I am alsso getting intermittent weak signal problems. This has been going on for some weeks now. I reported this in another thread but no one seems to have picked it up.
Can someone please let me know if action is required, as in Joeycag's issue?
  • Hi bdw 👋.
    Thanks for reaching out to us, sorry to hear of the red light issues that you are facing on your Hub, so that we can assist you we would need to bring you in for a private message. Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
    Thanks.
    Sabrina
