Nicholas2005's avatar
Nicholas2005
Network router hub 5 issues sometimes
Hey there I'm having issues with are houses WiFi, so ever since the new hub it doesn't do it as much.
The issue is the contant disconnections, up and down speeds and it's only when we ring em up it settles again. We also have had issues where the router restarted once and forgot itself and a new ssid for the router for some reason.
It might be the power up and down levels but it gets enough wattage and fine connection. I have checked the connections multiple times.
The issue is my mom is the WiFi holder, and she pays for it out of my money but she doesn't like the hassle of the support but for a service we pay like_70-100 for this is bad. Yes we have alot of devices but even then it should handle it in bandwidth control on the DHCP. It has happend on every hub
If a support agent sees this I'm happy to pass my mom's details or have look to send a engineer if any issues or upgrades. I am 20 but she gets the money from me for better speed because my hobby and future work is internet based as a IT network technian.
Please help
Message me for details
  • Hi Nicholas2005 thanks for your post although we're sorry to hear of the concerns you've raised here.
    We have ran some checks on our side and there aren't any issues on the line we can see at the moment, how have things been for you since your post is this still ongoing for you?
    Can you come back to us with the tests as advised here in the thread?
    Many thanks
    • Nicholas2005's avatar
      Nicholas2005
      Down bellow I have listed my power levels and stuff
      Nicholas2005
      Is there any chance of having a look.
      1 139000000 1 42 QAM 256 1
      2 147000000 0.6 42 QAM 256 2
      3 155000000 0.1 42 QAM 256 3
      4 163000000 0.3 42 QAM 256 4
      5 171000000 0.7 42 QAM 256 5
      6 179000000 -1.1 42 QAM 256 6
      7 187000000 -1.4 42 QAM 256 7
      8 195000000 -1.6 42 QAM 256 8
      9 203000000 -1.9 42 QAM 256 9
      10 211000000 -2.2 42 QAM 256 10
      11 291000000 -5.5 41 QAM 256 20
      12 299000000 -5.6 40 QAM 256 21
      13 307000000 -5.7 40 QAM 256 22
      14 315000000 -5.9 40 QAM 256 23
      15 323000000 -6.2 40 QAM 256 24
      16 331000000 -6.4 40 QAM 256 25
      17 339000000 -6.4 39 QAM 256 26
      18 347000000 -6.5 40 QAM 256 27
      19 355000000 -6.6 40 QAM 256 28
      20 363000000 -6.7 40 QAM 256 29
      21 371000000 -6.9 40 QAM 256 30
      22 379000000 -7 39 QAM 256 31
      23 387000000 -7.2 39 QAM 256 32
      24 395000000 -7.3 39 QAM 256 33
      25 403000000 -7.2 39 QAM 256 34
      26 411000000 -7.1 40 QAM 256 35
      27 419000000 -7.2 40 QAM 256 36
      28 427000000 -7.5 39 QAM 256 37
      29 435000000 -8.1 39 QAM 256 38
      30 443000000 -8.5 39 QAM 256 39
      31 451000000 -8.6 39 QAM 256 40
      3.0 Downstream channels
      1 Locked 42 332 0
      2 Locked 42 229 52
      3 Locked 42 450 81
      4 Locked 42 263 43
      5 Locked 42 233 51
      6 Locked 42 171 62
      7 Locked 42 105 54
      8 Locked 42 92 35
      9 Locked 42 85 44
      10 Locked 42 127 36
      11 Locked 41 288 23
      12 Locked 40 314 36
      13 Locked 40 363 28
      14 Locked 40 441 42
      15 Locked 40 492 30
      16 Locked 40 573 30
      17 Locked 39 700 33
      18 Locked 40 885 34
      19 Locked 40 887 31
      20 Locked 40 1017 25
      21 Locked 40 1312 44
      22 Locked 39 1457 69
      23 Locked 39 2565 37
      24 Locked 39 2264 39
      25 Locked 39 2319 40
      26 Locked 40 2442 37
      27 Locked 40 2767 52
      28 Locked 39 3562 62
      29 Locked 39 4796 42
      30 Locked 39 4651 57
      31 Locked 39 5387 34
      3.1 Downstream channels
      41 94 4K 1840 QAM 4096 1108
      41 Locked 33 -15.3 1153975660 295079895
      Upstream
      0 49600000 47.5 5120 QAM 64 6
      1 43100000 47 5120 QAM 64 7
      2 36600000 46.8 5120 QAM 64 8
      3 30100000 46.3 5120 QAM 64 9
      4 23600000 45.5 5120 QAM 64 10
      3.0 Upstream channels
      0 ATDMA 0 5 22 0
      1 ATDMA 0 5 40 0
      2 ATDMA 0 5 8 0
      3 ATDMA 0 5 24 0
      4 ATDMA 0 5 33 0
      3.1 Upstream channels
      12 10.4 43.2 2K QAM 256
      12 OFDMA 208 74000000 5 0
    This is a near duplicate of the post of 2nd Jan :
    https://community.virginmedia.com/t5/Networking-and-WiFi/Network-connection-issues-on-the-gigabit-speed-package/td-p/5605197
    If you have a service fault, your mother needs to report that to VM again, but be very specific.
    e.g. do you have a connection stability issue ( lets see the Hub's signal stats )
    or do you have a Wi-Fi coverage issue ( invest in some more Wi-Fi coverage equipment )
    What ever you do, do not use the phrase "Wi-Fi" as a general term for an internet connection, the VM Hub or Ethernet connections.
      Nicholas2005
      No bro, because I pay for most the package my mom says I can sort it if want but obviously she wants to be updated to.
      I said the issue, not to be rude it has kept rebooting alot, making some devices bandwidth causing mac address filtering blocking the device. Coverage is fine if it didn't disconnect all the time. You right but the WiFi is what is causing the WiFi to reboot.
  • legacy1's avatar
    You need to forget using the hub in router mode and get yourself a better router with 1Gb ports with hub in modem mode.
  • Tudor's avatar
    Please supply some stats, details below:
    How to get stats from a VM hub (no need to logon to the hub)
    Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
    • Click on the “> Check router status” button
    • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
    • Click on the “Upstream” tab, copy the text and paste into your reply
    • Click on the “Networking” tab, copy the text and paste into your reply.
      • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
