Pepsi-Max's avatar
Pepsi-Max
6 months ago
Intermittent connection for nearly a month (Hub 4)
I'm at my wits' end with this issue. Status page always says intermittent signal, when the 24 hour countdown on this runs out it just resets to 24 hours, making it impossible to actually get help through that avenue. Going through AI assistants makes me lose the will to live. (Seriously, F all companies that are using AI assistants, AI is the biggest backwards step in recorded human history). I'm convinced that Virgin have created an elaborate wall of fake technical support designed to make it as difficult as physically possible to actually get real assistance.
In a nutshell, we've had an intermittent service for about a month now. Rebooting the hub usually (but not always) fixes the problem temporarily, leading me to believe the issue is with the hub itself. We've had it for about four years now, and we've had previous hubs die on us over time before. Sometimes we can actually go several days without issue, only for it to start recurring with high frequency again, but right now it's going on and off every couple of hours or even less.
Right now I can't even connect to the hub via the usual 192.168.0.1 address to perform a reboot, which is bizarre because I'm connected to the network just fine; I can ping other local devices. Just no internet connection. Apparently Virgin are performing scheduled maintenance in my area tomorrow morning. If the problem isn't resolved after that I will be fully convinced it's our hub that is fubar.
  • goslow's avatar
    goslow
    Try the automated service status number 0800 561 0061 to check for any faults in your area.
    If there is planned work, or a general fault, in your area you will not get any useful individual help from VM until that has cleared. Tech visits routinely get cancelled if an area fault is in place.
    Are you running a BQM to track your connection?
    If you can regain access to your hub, (a wired connection is best for settings changes) post your connection stat's as per Tudor's post
    Red light on hub 3 - unstable connection | Virgin Media Community - 5530986
    and one of the forum regulars may look them over for you to see if they are in spec.
  • I have regained access to my hub, so I've posted the downstream/upstream stats down below. I can't remember what they look like when everything's fine, but I do remember having problems with a faulty hub in the past where the numbers were much different. Granted, in that instance the connection wasn't intermittent, it was just incredibly slow. This time, the connection is fine when it's up in terms of ping/speed/packet loss, it just keeps cutting out.
    I haven't been using a BQM and unfortunately due to the nature of this problem with how unpredictable it is (it's possible that after my next reboot it might be trouble-free for a week before going weird again as happened recently), it could take weeks to collate any useful data. In the meantime I have a borderline unusable service. I've had to reboot my hub several times today alone.
    3.0 Downstream channels
    4162750000-0.637.4QAM2564
    1138750000-0.435.4QAM2561
    2146750000-2.234.9QAM2562
    3154750000-434.3QAM2563
    51707500000.638.6QAM2565
    61787500000.838.6QAM2566
    71867500000.137.4QAM2567
    81947500001.939QAM2568
    92027500002.139QAM2569
    102107500002.138.6QAM25610
    112187500000.737.6QAM25611
    12226750000-1.836.6QAM25612
    132347500001.439QAM25613
    14242750000038.6QAM25614
    152507500000.738.6QAM25615
    16258750000-0.239QAM25616
    17266750000-0.438.6QAM25617
    182747500001.738.6QAM25618
    192827500000.238.6QAM25619
    202907500000.238.6QAM25620
    21298750000-0.239QAM25621
    223067500000.638.6QAM25622
    23314750000-0.439QAM25623
    24322750000-0.738.6QAM25624
    25330750000-2.137.4QAM25625
    263387500000.739QAM25626
    273467500000.440.4QAM25627
    283547500002.240.4QAM25628
    364187500001.239QAM25636
    37522750000039QAM25637
    385307500000.539QAM25638
    ChannelLock StatusRxMER (dB)Pre RS ErrorsPost RS Errors
    4Locked37.35598800
    1Locked35.41778900
    2Locked34.92561000
    3Locked34.34568800
    5Locked38.60537700
    6Locked38.60537700
    7Locked37.35598800
    8Locked38.98326100
    9Locked38.98326100
    10Locked38.60537700
    11Locked37.63627600
    12Locked36.60965300
    13Locked38.98326100
    14Locked38.60537700
    15Locked38.60537700
    16Locked38.98326100
    17Locked38.60537700
    18Locked38.60537700
    19Locked38.60537700
    20Locked38.60537700
    21Locked38.98326100
    22Locked38.60537700
    23Locked38.98326100
    24Locked38.60537700
    25Locked37.35598800
    26Locked38.98326100
    27Locked40.36628700
    28Locked40.36628700
    36Locked38.98326100
    37Locked38.98326100
    38Locked38.98326100
    3.1 Downstream channels
    ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
    39944K1800QAM4096424
    Channel IDLock StatusRxMER Data (dB)PLC Power (dBmV)Correcteds (Active Profile)Uncorrectables (Active Profile)
    39Locked41-0.815962090
    3.0 Upstream channels
    ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
    14960000054.55120 KSym/secQAM645
    236600000555120 KSym/secQAM647
    32360000053.35120 KSym/secQAM1610
    43010000050.85120 KSym/secQAM648
    54310000055.85120 KSym/secQAM646
    ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
    3ATDMA0000
    4ATDMA0000
    5ATDMA0000
    3.1 Upstream channels
    ChannelChannel Width (MHz)Power (dBmV)FFT TypeModulation
    1210.456.92KQAM32
    ChannelChannel TypeNumber of Active SubcarriersFirst Active Subcarrier (Hz)T3 TimeoutsT4 Timeouts
    12OFDMA20853.400
    • Cardiffman282's avatar
      Cardiffman282
      Community elder
      Both 3.0 and 3.1 upstream power levels and modulation are off. Check for local faults on 0800 561 0061 and if none report it as a fault on 0345 454 1111 / 150.
    • John_GS's avatar
      John_GS
      Hi Pepsi-Max
      Thanks for posting and welcome to the community. Sorry to hear of any Broadband issues. I'll send you a PM now to help further.
  • goslow's avatar
    goslow
    An intermittent problem is exactly the sort of issue to use the BQM as it runs 24/7 to track your connection so you can review over time and see if any patterns emerge.
    Can't say I know enough about the data to advise but your upstream levels seem to be towards the highest end of the range usually quoted on here. Hopefully one of the regulars, who knows about the hub data, will comment on your stat's.
