jayhcee's avatar
jayhcee
intermittent internet connection on WIFI and ethernet connections
hi, I have a hub 4  M250 and tv360 which is connected via ethernet. I also have a stand alone smart tv which is also ethernet connected, The Internet connection via WIFI and ethernet intermittently stops working, I have a strong WiFi connection with the hub and it is the hub connection to the internet that is the problem, On WiFi I can go to settings on my phone, disconnect and connect the internet and immediately restore service. With the TV360 box and the stand alone TV the external apps will freeze randomly and it is not often we get to watch a whole movie without interruption.
I have a Hive connected via ethernet and a tp-link power line for the TV's as well as WiFi extenders connected via WiFi, There are also 3 laptops/chrome books in the household, 3 mobiles, 2Tablets, Hp multifunction printer,
Any insight as to what might be causing the issue and how to correct would be appreciated.
regards
john
  • The BQM URL doesn't work.  The stats are perfectly good at the point you took them.
    Could you please repeat:  What is your problem now?  As I understood it, your wired TV connections when using external apps (e.g. Apple TV?) would not stream well.   You mention a standalone TV which is wired to your router and streaming onto this TV is a poor experience.  From this you deduce that the circuit is the problem.  You're probably right but catching the problem is the challenge.
  • Zach_R's avatar
    Zach_R
    Hi jayhcee,
    Thank you for your post and welcome back to our community forums. We're here to help.
    I'm sorry to hear you've been having some issues with your broadband connection recently. Are these ongoing today? If so, have you noticed any kind of pattern as to when the issues occur?
  • jayhcee's avatar
    jayhcee
    Hi @Zach_R
    Thanks for reply, this has been an ongoing issue for over a year and happens daily. No real pattern exists. with regard my mobile it seems to happen after a period of idle, a quick trip to settings and disconnect from hub and immediately reconnect and I immediately have internet back . with both TV's  whilst using external apps, iPlayer, ITVX etc, I rarely get through a 40min playback any time of day without the internet connection being lost. The picture freezes then the sound drops some seconds later, circle of doom starts and it can be 10 - 15 mins later before I can reconnect. This can be any time during the stream. I have tried switching to another player  but nothing will load, so it would not appear to be the apps themselves which are not behaving.
    • Tom_W1's avatar
      Tom_W1
      Hi jayhcee thanks for your reply.
      So we've ran some checks and there doesn't appear to be any issues on the line currently so all should be working correctly.
      Approximately how many devices do you have on at one time on the WiFi as this may be a factor too? Additionally, we'd advise rebooting the Hub as it does seem to be a while since this has happened.
      We hope this helps and please report back to us.
      Many thanks
      • jayhcee's avatar
        jayhcee
        Hi .@Tom_W1,
        Thank you, I reset the hub using the online broadband trouble shooter , however within half an hour the TV (ETHERNET CONNECTED) froze and lost connection, it can take up to 15 mins to re connect. Maximum of 3 mobile phones connected at any given time, maximum 1 tablet and 3 laptop/chrome book connected at any time, but unusual for all to be connected at same time. There is a Hive connected by ethernet and 2 TV although only 1 at a time using internet, there is also a HP deskjet plus 4122 printer connected by WiFi. TV ethernet connection is through TP-Link powerline and I also have a TP-Link WiFi extender. I have tried to resolve several times by contact with virginmedia and an engineer even came out but was unable to find any fault as you also discovered, however it still continues to disrupt viewing and internet usage.
        regards
  • Sephiroth's avatar
    Sephiroth
    This could well lie in broadband circuit itself.  Therefore a couple of diagnostic measures would help:
    1/
    Set up a Thinkbroadband BQM (google that) and post the graph after 24 hours that coincide with the breaks you are experiencing.
    2/
    Please post your downstream, upstream and Network logs from the Hub's GUI.  This will tell us very quicklyu whether eyebrows need to be raised on signal/noise levels.
    Btw, for what it's worth, my TVs (apart from one connected directly to the TV360 box) are also fed by Powerline adaptors and I'm very satisfied with the solution.
    Finally, does the freeze happen to a TV that is directly connected to the TV360 box?
    • jayhcee's avatar
      jayhcee
      Hi Sephiroth,
      thanks for your insight. I have set up a BQM as suggested. I will update in a day or two.
      The TV connected to V360 has suffered when connected via powerline when accessing external apps, as use is not very frequent unable to comment on current situation.
      regards
    • jayhcee's avatar
      jayhcee
      [url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/9da2ca8b24460e8e51221cbf3f91f4fa31d5b2b9-01-10-2024]My Broadband Ping[/url]
      BQM and downstream log
      3.0 Downstream channels
      11390000003.840.4QAM2561
      21470000002.840.9QAM2562
      31550000002.240.9QAM2563
      4163000000240.4QAM2564
      51710000001.940.9QAM2565
      81950000001.640.9QAM2568
      92030000001.740.4QAM2569
      122270000001.538.6QAM25612
      132350000001.540.9QAM25613
      152510000001.240.4QAM25615
      162590000001.240.4QAM25616
      172670000001.240.4QAM25617
      182750000001.440.9QAM25618
      192830000000.940.4QAM25619
      202910000000.740.9QAM25620
      21299000000140.4QAM25621
      223070000001.340.9QAM25622
      233150000001.540.9QAM25623
      243230000001.540.4QAM25624
      253310000001.240.4QAM25625
      263390000001.340.9QAM25626
      273470000001.540.4QAM25627
      28355000000140.4QAM25628
      293630000000.940.4QAM25629
      303710000001.240.4QAM25630
      31379000000140.9QAM25631
      323870000000.840.4QAM25632
      333950000000.640.4QAM25633
      344030000000.440.9QAM25634
      364190000000.440.9QAM25636
      375230000000.140.4QAM25637
      385310000000.240.9QAM25638
    • jayhcee's avatar
      jayhcee
      upstream log
      interuption today mid morning 9- 11am
      • jayhcee's avatar
        jayhcee
        this time with upstream log
        3.0 Upstream channels
        136600000455120 KSym/secQAM643
        223600000455120 KSym/secQAM645
        330100000455120 KSym/secQAM644
        44310000045.55120 KSym/secQAM642
        549600000465120 KSym/secQAM641
        3ATDMA0000
        4ATDMA0000
        5ATDMA0000
        3.1 Upstream channels
        610.048.72KQAM128
        6OFDMA20053.900
    Sephiroth
    • legacy1's avatar
    • jayhcee's avatar
      jayhcee
      https://www.thinkbroadband.com/broadband/monitoring/quality/share/25af34bb2e63319410657fd96cbead785f0bfcbe-02-10-2024
      Hi, Thank you for quick response.
      This link should work. graph still shows, just, period between 9-11 yesterday when the dropout occurred twice. I now have a months BQM graphs
      My issue is still as was, in that my mobile Nokia G11 suffers an intermittent internet outage despite showing good wifi connection. If I disconnect the wifi connection on the phone and immediately reconnect the internet is restored, in addition both a TV connected to TV360 and a standalone TV have suffered from outage and from buffering. Tv connected to 360 has been trouble free for a while however it is only used occasionally for short periods 30 mins or so at a time. The standalone will suffer from buffering/dropout frequently. I have removed the ethernet connections to the TV360  and the standalone TV ( both via powerline) and removed a wifi extender which was not connected to the standalone TV the only other connections to the hub is a Hive connected by ethernet and currently a maximum of 2 phones, a tablet , 2 laptops, 1 printer. Other family members have experienced similar issues  with mobile  and laptop when connected to the hub, and although they no longer reside here the issue continues. I also use VPN on phone and laptop, could this be an issue?
