Simon49's avatar
Simon49
11 months ago
Hub Red light
I have had a constant Red light  on my HUB for the last few weeks. I have checked the message boards and followed other peoples suggestions.
I have reset the hub from the reset button for30 sec, and disconnected the hub. The red light still persists.
No change to the Hub though Any help?
  • Hello Simon49
    Thanks for taking the time to post in regards to your Hub and the red light showing constantly, we understand the concern this can cause and you posting on the forums. Welcome to the community.
    In instances such as this it can be an overheating Hub or a faulty LED, I appreciate you have advised you have tried the steps but please can you try this for me:
    • Ensure the Hub is upright, in a well-ventilated location and out of direct sunlight, if possible.
    • Switch the hub back on at the power. The Hub should now operate normally.
    I will send you a Private Message, please keep an eye out in the top right when signed into the forums for the envelope. This is where you will be able to find my Private Message and be able to respond.
    If the Hub is warm to touch, please don't use when unattended.
