deepakbhota's avatar
deepakbhota
4 months ago
Hub 5 Paused Device gets unpaused automatically
Hello,
I have been facing an issue in VMConnect app. Whenever I pause a iphone accessing my wifi, it gets paused. When I close VMConnect and reopen I see the same phone is unpaused.
Can Someone help here and guide me what I need to do ?
    Have you confirmed the iPhone's MAC address has remained the same at this time? A lot of modern devices rotate MAC addresses as a security feature.  One of the reasons that MAC address pausing fails.
    • deepakbhota's avatar
      deepakbhota
      Thank you so much for the response. No the MAC address keep changing.
    Wi-Fi Pausing is an over two decade old idea that is now easily defeated by a 2025 mobile or laptop.
    Be careful not to fill the Hub with ever more Paused entries, it is the fastest way to find all sorts of kit has stopped working and the errors reported can be very obtuse.
  • Hi deepakbhota,
    Thank you for your post and welcome to the community.
    We're very sorry to hear about the issue with your connect app.
    Can you confirm if you have been able to check what Adduxi has advised?
    ^Martin
  • legacy1's avatar
    The only why to do Paused Device right is per SSID per person to then Pause the give SSID even then VM would make a mess of it.
  • So whats the solution ? How could I do that. I want to reduce mobile access for my kids.
    • legacy1's avatar
      Buy a AP that can do many SSID with time access I'm not sure if there are AP you can get that can linkup to pause a given SSID by app on your phone like but timed access is found on most AP but may depend on how many times in the day you want the reduce access.
